Oil pressure wanders when cruising
Old Mar 19, 2014 | 04:25 PM
SlicktopS130's Avatar
I'm not sure how long this has been going on, but i just noticed it a few days ago. When i'm cruising along, maybe 2500 RPM in 5th, the gauge needle starts going a bit wacky. The needle will move frequently from about 25 PSI to 45 PSI, only once the car is warmed up (Over 120 degrees). When cold, pressure seems consistant between 40-50PSI based upon RPM. I've heard that these gauges arent that accurate, but is this fluctuation normal?
Using 5 QT's of Mobil 1 10w-30 EP with a Bosch filter. Oil was changed two weeks ago.
Old Mar 21, 2014 | 08:25 PM
Replace oil sending unit (oil pressure sensor). Fairly common problem.
KSpakes87
Apr 25, 2013 06:54 PM
87zxt
Nov 18, 2012 03:02 PM
RandomHero
Aug 22, 2011 10:36 AM
kenpomgm
Mar 16, 2008 04:51 PM
thetremendousti
Oct 4, 2007 11:40 AM
