no spark after r&r
Old Apr 17, 2017 | 08:30 AM
studio110's Avatar
no spark after r&r
I removed my oil pump and distributor on my 83 zx turbo. this was running good before r&r. after i reassembled no spark. I Have checked everything. no spark. If it is a ground issue, what would be the likely spot? does anyone have any thoughts? Ecu seem ok.
Old Apr 17, 2017 | 09:39 AM
I think you left out a few details...
So, literally the ONLY things you touched were the fuel pump and distributor? Never disconnected the battery? Never unplugged ANYTHING else?
#1: Check for power at the coil: With key on, is black white stripe showing 12v?
#2: Is distributor base plug and round black harness plug securely connected?
#3: Is coil bracket securely grounded?
#4: Is ecu green light on?
I'd say you either left something disconnected, or blew a fusible link.
Old Apr 17, 2017 | 12:19 PM
studio110's Avatar
i disconnected the battery and i did have the coil off the fender well. i was replacing hoses that went to intake. i will take your advice and recomendations .
thank you!
Old Apr 17, 2017 | 12:20 PM
studio110's Avatar
thank you!
ps, it was the oil pump i remove not the fuel pump.
Old Apr 21, 2017 | 08:16 AM
Yes yes... oil pump. Any updates?
Old Apr 21, 2017 | 02:40 PM
studio110's Avatar
I had put a gasket between the distrubutor and the engine. i thought maybe it wasn't letting the dizzy ground. after removing gasket no change. Going to keep you posted. have not found it yet.
G30
Oct 14, 2014 03:54 PM
Fairladyz1990AF
Apr 24, 2014 04:15 PM
Knightly
Jun 30, 2013 07:34 PM
rar7775
Jan 15, 2010 06:21 PM
ZsNRexs
Oct 19, 2002 08:02 PM
