no spark after r&r
I removed my oil pump and distributor on my 83 zx turbo. this was running good before r&r. after i reassembled no spark. I Have checked everything. no spark. If it is a ground issue, what would be the likely spot? does anyone have any thoughts? Ecu seem ok.
I think you left out a few details... :)
So, literally the ONLY things you touched were the fuel pump and distributor? Never disconnected the battery? Never unplugged ANYTHING else? #1: Check for power at the coil: With key on, is black white stripe showing 12v? #2: Is distributor base plug and round black harness plug securely connected? #3: Is coil bracket securely grounded? #4: Is ecu green light on? I'd say you either left something disconnected, or blew a fusible link. :) |
(Post 345863)
So, literally the ONLY things you touched were the fuel pump and distributor? Never disconnected the battery? Never unplugged ANYTHING else? #1: Check for power at the coil: With key on, is black white stripe showing 12v? #2: Is distributor base plug and round black harness plug securely connected? #3: Is coil bracket securely grounded? #4: Is ecu green light on? I'd say you either left something disconnected, or blew a fusible link. :) thank you!:) |
Originally Posted by studio110
(Post 345864)
i disconnected the battery and i did have the coil off the fender well. i was replacing hoses that went to intake. i will take your advice and recomendations .
thank you!:) |
Yes yes... oil pump. :D Any updates?
(Post 345887)
