No spark 280zxt (help!!)
Old Feb 20, 2009 | 12:43 PM
mikep's Avatar
I searched and couldn't find the answer.My 83 280zx turbo isn't getting any spark.The ecu,ignitor,distributor,coil,afm are in good working condition.I know this because i tested them all on my other 280zxt.
I cleaned all connectors,pulled the ecu plugs in and out 8 times and still no start.I did use one of those spark plug testers.Could a bad ignition switch be the problem?Any advice?
Old Feb 20, 2009 | 01:06 PM
280zx2by2's Avatar
Haterade by da gallon!
you should go buy a digital multimeter(you can get them at autozone or advanced auto whatever) its only like $13 and it helps ALOT with what your dealing with
one bad wire or connection could be your culprit
Old Feb 20, 2009 | 01:28 PM
Is the coil bracket that grounds the ignitor securely grounded to the body? The ignitor must be grounded or no spark...
Old Feb 20, 2009 | 03:25 PM
mikep's Avatar
Yes, the coil bracket is tight and secure.I'll re-check all of the connections.
Old Feb 20, 2009 | 03:43 PM
Is the ecu getting power?
Old Feb 20, 2009 | 03:46 PM
mikep's Avatar
Yes, the ecu is getting power.The fuel pump turns on for the 5 sec period.That's why i was thinking it maybe the ignition switch.
Old Feb 26, 2009 | 04:28 PM
straight hate's Avatar
I went through two ignitors in three months. Same ****, no spark, it would die at idle, all sorts of weird stuff. Even replaced the CAS(lifetime warrenty, why not.). Bad ground. Cleaned battery terminals, took all the grounds off cleaned em' and put a little grease on the bare metal to cut the corosion. No problems so far and its been 8 weeks, at least. I think those ignitors are pretty sensitive to resistance. Worked for me, FYI.
Old Feb 28, 2009 | 03:54 PM
mikep's Avatar
Iv'e been out of town for the week and didn't have time to work on the z.Thanks for everyone's input.I'll be working on my car in a few days.I'll re-check all connectors and grounds.
murdockshady
Jan 28, 2015 05:36 PM
G30
Oct 14, 2014 03:54 PM
Fairladyz1990AF
Apr 24, 2014 04:15 PM
KSpakes87
Feb 7, 2013 03:30 PM
Beseke
Jul 26, 2005 11:16 AM
