New problems with the 82 turbo
Old Feb 22, 2005 | 07:30 AM
MetalZ's Avatar
alright; i got it goin; but the second day it was running it started running really shitty; the spark plugs are fowling out; and it just runs like utter ****; it's running RICH; not rich; but RICH; as in a LOT of gas; anyone help please still new and desperate; thanx.
Old Feb 22, 2005 | 07:35 AM
Check or replace the fuel pressure regulator.
Did your oxygen sensor get unplugged?
Old Mar 2, 2005 | 06:55 PM
ZXT DAVE's Avatar
I had the same problem with my 79 NA which I have since dropped an 82 turbo engine into. I figured that it had a fuel efficiency of one gallon per mile! That's right, fourty miles on a tank and making an huge embarrassingly black and stinky cloud behind me as I drove. I tried all kinds of stuff including the fuel pressure regulator. It ended up being the simplest of things. The connectors for the temp sensor(s) at the front of the engine were corroded. These wires that travel to the ECU have connectors under or along the fuel rail beside the first three injectors. (general vicinity) Pull the connectors apart and clean them there and prhaps where they connect to the sensors them selves. There are two or three sensors up there. Chances are if one connector is dirty then they all are so clean them all. It solved the problem for me.
Good luck,
ZXTD
Old Mar 5, 2005 | 02:01 PM
MetalZ's Avatar
thanx i'll try that; it's raining right now; so it will have to wait; but thanx. It was runnin GREAT for like 2 days and then just turned to utter crap.
merlinthewzrd
Feb 1, 2014 07:42 PM
dce2005
Feb 18, 2013 01:11 PM
jbiddle530
Oct 3, 2012 12:25 AM
drift240z
Jan 4, 2005 06:58 AM
speedricer05
Apr 2, 2003 12:01 PM
