Need Advice ??????????????
Old Dec 21, 2006 | 08:21 AM
runningjalapeno's Avatar
Cool Need Advice ??????????????
I have a 1983 nissan 280 zx turbo when I turn the car on in the morning it will idle fine until it warms up the it will start to idle very bad from 600 rpms down to 100 rpms, it was turning off at every red light if I didn;t keep pressing the gas peddle I adjusted the idle screw to idle higher, now it does not turn off but it will idle very bad. any suggestions the car has 127000 miles .
Old Dec 21, 2006 | 08:25 AM
There's no idle screw on the turbo model... unless you are talking about the throttle body stop screw???
Anyway, check your air regulator & all the hoses attached to it.
Old Dec 21, 2006 | 08:26 AM
naviathan's Avatar
Sounds like a vacuum leak to me.
Old Dec 21, 2006 | 09:36 AM
z-hag's Avatar
Queen of Yachts
check your vacuum lines, check your afm, if that car has one, check your o2 sensors, if that car has them-----and your idle adjust after all that.
good luck--did i miss anything??
Old Dec 21, 2006 | 07:08 PM
ToxicZ's Avatar
Vacuum is a likely culprit. If you adjusted a screw, it was likely the afm mixture adjust screw. You may have been getting bogged down with fuel in low rpms becuase of improper vacuum. Your afm adjust leaned out the mixture to allow the car to warm idle at low speed.
Unplug various vacuum lines and monitor change in idle performance, do the same with valve cover cap. This should track down your problem if it is indeed related to vacuum.
Old Dec 21, 2006 | 08:36 PM
duowing's Avatar
NisTuner
My guess is he adjusted the screw on the throttle body that would deal with the idle. I would say check your O2 sensor and your TPS, and definitely check your timing.
Old Dec 22, 2006 | 07:01 AM
how does it run when you put the pedal to the wood? does it go, or does it kinda seem sluggish, casue if so, change your fuel filter. it can make the world of difference
Old Dec 22, 2006 | 07:05 AM
FubarI33t's Avatar
Get the car warm. Get it to where she idles bad. But stay at your house. Do a few laps around the neighberhood. Pull the large vaccume line coming from the charcoal canister, It's called the Purge. If she idles better then your runing rich. Doing this will alow Unmeterd air intot he intake to help make up for the fact of ver fueling. But don't drive like this. If this work's or even don't work. check the stuff Duowing said. if you can. take the rubber boot off the T/B and see How closed it is(the car should be off) If it's snaped closed. adjust the top screw a lil to open her up. But not much. The turbo's don't have a cold start. So it could be a bad sensor. maby the head temp sesnor
Old Dec 22, 2006 | 09:45 AM
thank you all for all the info i will be doing all this during the x-mas break thank you again I will post some pictures of my car and me when i bought it new in 83 and then some recent ones we are both getting older and slower the good think is that I can replace what breaks on the car.the bad what goes out on me i have to live with it I think my car is going to out live me.
Old Jan 31, 2007 | 11:25 AM
280 zx turbo will not start
hello my car a1983 turbo will not start was running rough so i cleaned some of the connection put dietric grease on the connections now I will not get a spark no fire at all will rotate great but will not start I took out the ECU and replaced it with another one and still no fireor spark I have plenty of fuel i can smell it very strong. any one selling a distriubtor for a 1983 turbo car?
Old Jan 31, 2007 | 11:46 AM
Make sure the coil bracket & IC piece are securely grounded. You won't get spark if those aren't grounded.
Old Jan 31, 2007 | 12:09 PM
and teh grease... maybe too much? i noticed that if there is anything but total dryness on all the connections on these cars they dont run or start at all... when i got mine wet i let it air dry for 10 days and she started right up....
Old Jan 31, 2007 | 06:01 PM
GTR's Avatar
GTR
Badass Z Chick
I'm sad, i could help, seeing that we kinda live in the same city if you still live in corpus, but alas, it is not so ..........hmmmmmm, lemme look at it, i can figure it out, and if not you can sell it to me for like $5 ^.^...........j/k, are you even getting power or a pulse signal to your coil......that's just my two cents and a shot in the dark......i like looking at cars when giving advice and know very little about these turbos........well gotta run back home
drey
Aug 10, 2011 03:54 AM
n00blar
Jun 19, 2007 07:14 PM
efrain
Sep 17, 2005 07:20 AM
280ZX_AV8R
Aug 27, 2005 06:08 PM
Dave
Apr 14, 2005 04:14 PM
