Max Boost ?
Old Oct 13, 2005 | 10:38 AM
  #26
Originally Posted by Bleach
That's what I would suggest. 10 psi absolute max but to keep it safe, just set it for 8psi. The manual controller (even a good one that doesn't spike much) will probably spike to 10psi and then drop back to 8.
and w/ the stock manifold pop off valve, you'll know when ya get to 8psi
Old Oct 13, 2005 | 11:09 AM
  #27
lww's Avatar
lww
Head Muckraker
Originally Posted by nismo619
im looking for advice for my 1982 280zx turbo with 120,000 miles on it im not asking for u people to be rude to me . Next was the safest boost to run with my manual boost controller that i got from a friend off hear from zdriver.com now with out no jokes no rude jokes and no misleading information can some one thats totaly sure give m the safest boost i can run ? im thinking 8 or 9
Nismo619, all the sarcastic replies were directed to the Turbo280z guy. Sometimes it's hard to follow these threads when people don't use the 'Quote' option so you can't really tell who they're talking too/about.
In my opinion, the safest boost level would be 9 to 10 psi. No one can be totally sure because we don't know the condition of your motor. The more boost you run the harder it'll be for the motor to deal with it. If the motor is in pristine condition and heavily modified (like mine) you can run pretty ridiculous boost levels (I'm at 25psi). If it has 100k+ on it with questionable maintenance you have to be more careful.
Do a full leakdown compression test first. This will give you an idea of how good your rings are and if there's any inconsistency from cylinder to cylinder. That combined with the total mileage on the motor and we may be able to give you a little better advice.
Cheers,
LWW
Old Oct 13, 2005 | 06:46 PM
  #28
s/cL3.0's Avatar
Bleach is my Hero
Originally Posted by lww
(I'm at 25psi).
Is that the car that has been in the shop for 8months?? Do you run water injection or a sprayer at all??
Old Oct 13, 2005 | 09:37 PM
  #29
RodMoyes's Avatar
Doesn't post much...
Hey S/CL3.0
If you want to put that pic as your signature, you just need to make it a little smaller. Most photo progams can shrink it easy enough, or you can get "JPEG Compress" software for free and do it. I forget the maximum sixe criteria but I thinks it's something like "no bigger than" 600x600 or something like that... yours is like 680x460ish
Rod.
Old Oct 14, 2005 | 05:40 PM
  #30
s/cL3.0's Avatar
Bleach is my Hero
Originally Posted by RodMoyes
Hey S/CL3.0
Rod.
Yeah I am being a smart ***.. [dont think I dont know it was you Ldub that swapped my SIG]
Old Oct 14, 2005 | 06:32 PM
  #31
lww's Avatar
lww
Head Muckraker
Yes, except now it's been over 9 months...
No water injection or sprayer...
Old Oct 14, 2005 | 06:33 PM
  #32
lww's Avatar
lww
Head Muckraker
Dude! It wasn't me! It must have been Bleach!
Old Oct 14, 2005 | 06:37 PM
  #33
uuhhh... Riz did it! Those Z32 drivers are always up to no good
Old Oct 14, 2005 | 07:13 PM
  #34
s/cL3.0's Avatar
Bleach is my Hero
Hey you.. you said it was LWW hehe.. My friend was auto xing [the one putting down 550RWHP] and his wastegate gasket blew and melted his H20 line.. so scary.. Thought it was done for.
Old Oct 15, 2005 | 09:34 PM
  #35
nismo619's Avatar
ok so i hook up the manual boost controller to the Accuater then to the manual boost controller then i block off the compressor hole right ? so there is a little hose from the accuater to the compressor side ? so for me to put on the manual boost controller all i have to do is hook up the hose from the accuater to the manual boost controller then to a t pipe fitting on the manifold ontop by my POV but i still have to block off the compressor side am i right ? my friend told me thats how to do it i will be running only 7psi to test and im not listing to u people saying boost to 1,000,000 psi !!! watch my car turn into a space shuttle and take off lol HEHEHEHE sorry i kinda got affended all i want is honest advice ;-)
Old Oct 16, 2005 | 12:02 AM
  #36
lifegrddude's Avatar
Externally Wastegated
Take the vacuum line coming out from the compressor, connect it to the boost controller's "in" port, and then take the "out" port's line and hook it up to the actuator. Or at least that's how the installation of my Profec B was. I'm pretty sure most other boost controllers would be hooked up in a similar fashion. All it is, is run in series with the vacuum line.
Old Oct 16, 2005 | 08:05 AM
  #37
s/cL3.0's Avatar
Bleach is my Hero
oops yeah I forgot to check if you were putting it on the inor out port when I was helping you last night.. sorry
Old Oct 16, 2005 | 09:13 PM
  #38
nismo619's Avatar
ok i hooked it up and ran my car a few times at first i didnt think it was working at all so i checked eveything and then i fixed the problem i turned up the boost but then PIFFFFFFFF i heard the POV sound like a chattering squrial .... so i turned it down and no problem.. but how do i get to 7 psi on my stock 280zx turbo boost gauge with out the PIFFFFFF sounds ?do i really have to modify the POV ?i was thinking about blocking it off but i have decided thats wayyyyy to risky but the link i was sent show how to modify the POV but im afriad there might be a point of no return.. ? ( but eather way the manual boost controller is ON !!!! YAAA !!!!) p.s. i was in second gear and the little line barly got up to the red line on the boost gauge ? maybe i need and external boost gauge huh ?
Old Oct 16, 2005 | 09:36 PM
  #39
do i really have to modify the POV ? i was thinking about blocking it off but i have decided thats wayyyyy to risky but the link i was sent show how to modify the POV but im afriad there might be a point of no return.. ? ( but eather way the manual boost controller is ON !!!! YAAA !!!!) p.s. i was in second gear and the little line barly got up to the red line on the boost gauge ? maybe i need and external boost gauge huh ?
"do i really have to modify the POV ?"
-You don't HAVE to... but ya won't ever boost above ~7.5 psi w/ it stock. It's there for a purpose. You have 3 options... 1: Modify it, 2: Cap it, 3: Get the aftermarket one from MSA.... You choose.
FYI... you should have installed an external boost gauge BEFORE doing the boost controller. How ya gunna know what boost ya at?
VanBruno
Nov 2, 2014 10:16 PM
lilotanni
May 10, 2011 04:33 PM
1SIKZ
Mar 12, 2006 11:39 AM
jtmny1999
Apr 3, 2003 07:40 PM
DVSTT
Oct 18, 2001 06:09 PM
