loss of coolant
loss of coolant
Hi,
As if I need another problem to worry about. I took it for a 30 miles ride tonight and as soon as it warmed up I started smelling a funny smell. After the ride, I checked the coolant reserve tank and noticed that it's almost empty. It is not heating up, but I think the smell that I'm smelling seems like coolant coming from somwhere, no leaks on the floor or anywhere on the car though.
Please help, do I have a problem? Should I take it in? I am not that experienced to do a major repair job.
Thanks
Thanks
Can you just look for the leak? Park it on pavement and leave the engine running. If it is leaking enough to worry about you'll see drips. The resivour doesn't always have coolant in it though, especially if the radiator is not totally full. Maybe you do have a very small leak so the radiator isn't full all the time.
Check the upper and lower radaitor hoses. On the passenger side of the engine, check the hoses going through the firewall. Those go to the heater core. On the front where the upper radiator hose connects to the engine, check that thermostat housing and the base that mounts to the block. If any of it is wet or has white stains then that is a sign of a leak.
Originally Posted by zfanman
Hi,
Thanks
Thanks
It could be something as simple as the resivoir has a leak to the water pump going bad.
If you still have the lower splash guard under the motor, take a peek there. If you see coolant laying on the splash guard, it's either the lower hose, water pump, or a leak in the res.
coolant
Hi,
Thanks
Thanks
