at a loss...
Old Dec 15, 2002 | 08:22 PM
duckyz's Avatar
at a loss...
I've tried everything short of a complete rebuild to get my '83 ZX back in running order, fuel pump, plugs, wires, cleaned out the air regulator.....hell you name it. Everytime I crank it, it lopes HARD, blows buleish/white smoke, and won't idle unless I keep my foot on the gas and the rpm's between 1K and 2500. I let off the gas and it stalls. I give it more gas to rev the motor and it bogs. Granted, I should be shot for letting it sit for 4 years, but it used to work fine, and I even dorve it to work for a month last year. Then she just quit on me. Wouldn't even start. At least now, she starts...
Any ideas???
Old Dec 15, 2002 | 09:30 PM
lifegrddude's Avatar
Externally Wastegated
Re: at a loss...
When it runs does it sound like it fires on all cylinders? Have you checked your fuel injectors out and the connectors? If it was sitting for 4 years those plastic fuel injector connectors can go bad and not be connected all the way giving a bad signal to the CPU, I had to replace 3 already. Still, blue smoke isn't giving a good sign cause that means oil burning...
82ZXT
71 510 autocross & 71 510 daily driver
Old Dec 16, 2002 | 10:31 PM
duckyz's Avatar
Re: at a loss...
The injectors seem to be fine....like I said, short of a rebuild, I'm at a total loss.........
I'm thinking of messing with the fuel/air mix. The plugs are wet when It totally stops running.
Fozy
Mar 28, 2011 07:42 PM
mikesz
May 29, 2008 11:06 AM
thxone
Dec 4, 2006 04:39 PM
emo236
Aug 6, 2005 05:35 AM
Cw2435
350Z Performance / Technical
14
Feb 22, 2004 10:33 PM
