Intake Manifold Modification
Old Mar 20, 2013 | 07:11 AM
tamug92's Avatar
Meant to post these pics a couple of months ago. I was having a hard time getting to the intake and exhaust manifold bolts underneath after installing a rebuilt head and new header. Read on this forum about a few guys cutting out the webbing on the intake and it made a huge difference. I can see/reach everything now. just used my air tools/body saw and made short work of it.
Attached Thumbnails Intake Manifold Modification-northeast-harris-20121221-00659.jpg   Intake Manifold Modification-northeast-harris-20121221-00658.jpg   Intake Manifold Modification-northeast-harris-20121221-00657.jpg
Old Mar 20, 2013 | 08:13 AM
Nice! Lot of work, but it helps. Just an FYI... you need to reinstall the heat shield to prevent heat soak into your intake mani.
I de-webbed a turbo intake a few years ago (N42 Left - L28ET Right)...
Old Mar 20, 2013 | 11:36 AM
tamug92's Avatar
Very nice job, makes mine look like i did it with a broken Heineken bottle! I was afraid I would have to put that heat shield back so good thing I didnt chunk it.
Old Mar 29, 2013 | 10:15 PM
pnoyslimm's Avatar
what did you use to cut with?
Old Mar 29, 2013 | 10:39 PM
Not sure what exact tools tamug92 used, but:
https://www.zdriver.com/forums/280zx...uestion-34887/
When I de-webbed my turbo intake (search my posts for pics), I used a drill to put holes around the edge where the runners / webbing meet, then knocked out the webbing chunks with a hammer. Then rough finish the left over "nubbins" with a cylinder shaped carbide tooth drill bit, and smooth it off with a ball tooth bit. We've discussed dewebbing before... thus the reason for research before work.
Old Mar 29, 2013 | 10:41 PM
MurphyEF's Avatar
^This is the process I used. Makes things -way- easy, though mine had more of a pointed tip. Same concept.
Old Mar 30, 2013 | 08:31 AM
yup i did it a few years back. i found the intake trapped tons of hot air beneath it so i cut the webbing out. mine doesnt look pretty but i never finished it as my car was my dd. now im gonna build a better intake with large runners. you definetly need the heat shield, it lowered the manifold temps quite a bit on top of what cutting the webbing out did.
Old Apr 1, 2013 | 12:09 AM
That looks like half way between a ferrous style burr and a helical cut aluminum bit. There is a straight helical cut that's designed more for aluminum. You'll find the burr load's up pretty easily and it's a bit of a pain to clean it out. I use a dental pick to get the chunks out of the burr. Also cutting wax helps cut faster and extends the life of your bits...
Old Apr 3, 2013 | 11:10 PM
MurphyEF's Avatar
I'm actually about to do another manifold myself. Gotta keep the Z up as my DD, yet still want to put on my 60mm TB. Sucks that I don't have an air compressor anymore, though.
Old Apr 25, 2013 | 11:43 AM
a280drvr's Avatar
Just wne to local production tool and they're ordering me a bit like nismo's except it's for aluminum. Showed them the pic told em what I'm doing and he opened up a book and said this ones better. Getting that, 3 1in flapper wheels and a stick to clean **** off sandpaper. Only costing me $30 for everything. I'm going to atempt this on my extra turbo intake before doing my dd intake. Any tips for someone never done this before? Especially on the porting...
Old Oct 12, 2014 | 07:49 AM
Richard5001's Avatar
can this be done on the vehicle or do you have to remove first?
Old Oct 13, 2014 | 12:17 PM
Anything is "possible", but leaving it on the car you'd probably be suicidal by the time you finish. The intake is fairly simple to remove... don't make it harder than it needs to be.
Old Oct 13, 2014 | 12:20 PM
Thanks for the advise. Already have the front suspension off the vehicle the heat shield is easy to get to
noelawinslow
May 21, 2013 01:17 AM
static2430
Nov 10, 2008 11:37 AM
Niku-Sama
Jan 17, 2008 05:03 PM
veyenyl
Mar 10, 2007 09:47 AM
Captain caveman
Aug 11, 2005 10:14 PM
