Intake Manifold
Old Jan 2, 2006 | 04:41 PM
Intake Manifold
Hey Guys Sombody Has Got To Want This Its A Custom Dual Throttle Body Intake For An L Series Engine Its On Ebay And I Cant Make A Link. Its Called Custom Intake Manifold 240 280zx. Really Cool For Anybody That Needs Mega Air Flow In An Fi Application Its Got 5 Days Left.
100 Dollars
Old Jan 2, 2006 | 04:46 PM
100 Dollars
This should be the link to it.
click here for sure this time
Old Jan 2, 2006 | 04:49 PM
I can't get it to work for some friggin' reason. Will keep trying though.
Old Jan 2, 2006 | 04:50 PM
I Put A Bid On It For The Bob Sharp Race Car. 110 Bucks Thanks For Workin On The Link Thingy
Old Jan 2, 2006 | 05:11 PM
Okay I got it to work this time. I just had to remember how to do it. You can click where I first posted or I can put it here also.
click here also
Old Jan 2, 2006 | 05:12 PM
the "working" link
Old Jan 2, 2006 | 05:34 PM
I beat you to it.
Old Jan 2, 2006 | 07:25 PM
jfairladyz's Avatar
Ooh thats sweet and it comes with a manifold Good luck with your bidding.
Old Jan 2, 2006 | 08:15 PM
I Shall Try, Looks Really Good, Almost Period For The Race Car. If I Dont Get It Then I Will Build One Now That I Have The Idea. I Love Stealing Ideas.
Old Jan 2, 2006 | 10:00 PM
jfairladyz's Avatar
Just remember, as long as you improve an idea you stole then its research & development
Old Jan 2, 2006 | 10:10 PM
jmmorriso's Avatar
might as well just make one from scratch, i think the 240 runners might be a little restrictive? i know nothing about l sreies carbed stuff. I envision equal length tuned runners, more modern injector attach points, and for god's sake just leave it natural aluminum.
Old Jan 3, 2006 | 07:57 AM
They should be the same size runners as the FI version, as the ports in the head are just about the same.
Old Jan 3, 2006 | 04:13 PM
The Best Thing About That Intake Is That 3 Cylinders Are Fed By 1 Tb. So Your Restricted By The Cam, Not By The "log" That Our Fi Manifold Has
Old Jan 7, 2006 | 10:16 AM
Looks Like Somebody Really Wants That Intake. I Ran His Bid Up Past 140.00 So He Gets Screwed A Bit. Ill Go Back Later And Make Sure He Really Pays For It. Ill Pay 150 For It But Anything More Is Crazy
Old Jan 7, 2006 | 01:03 PM
s/cL3.0's Avatar
Bleach is my Hero
hmmm.. I wonder
Old Jan 7, 2006 | 07:35 PM
Whats That Sc. Is That You Bidding, Or Ya Thinkin Of Building One. I Think That Is The Route Im Going To Go. I Bid 150 And The Other Guys Ebay Countered Right Away. At Least Hes Payin For It.
Old Jan 7, 2006 | 09:26 PM
EatmyDust's Avatar
how and where dose the tps mount? or is it the same just one extra tb?
Old Jan 8, 2006 | 12:01 PM
I Dont Know Really Wasnt Important To Me. I Just Looked There Is An Hour Left And Some Fools Have Got It Past 220 Bucks.
Old Jan 8, 2006 | 12:23 PM
lww's Avatar
lww
Head Muckraker
BUZZZZZZZZZZZ! Wrong answer!
Actually, the runners in the 240Z & 260Z carbed intake manifolds are 1.37" internal diameter and the FI manifolds from the 280Z & 280ZX are 1.25" internal diameter!
So, actually, the 240 & 260 carbed manifolds flow more volume of air than the FI mainfolds!
So, this configuration has more potential than the stock FI manifolds and is why FI guys making really big power are using custom manifolds with larger runners and properly designed surge tanks.
I'm not sure the surge tank included in this auction meets that criteria as it would have to be run on a flow bench to verify the efficiency of it's design.
Also, TWM now makes a "direct" bolt on ITB replacement for the dual SU carb's.
http://www.twminduction.com/Throttle..._throttle.html
Of course, they're charging a little more than the $220 that the ebay piece is currently going for.
You guys need to learn how to bid using ebay. NEVER make a bid early. Typically, I wait until the last 5 seconds on something I'm seriously interested in. This minimizes the possibility that someone will come back in a day or two and place a counter bid. If my max bid isn't enough to win it in the last 5 seconds, then it just wasn't meant to be.
I won a newly rebuilt set of CV axels for $80 this way!
Old Jan 8, 2006 | 12:35 PM
I Usually Put One Just Higher Bid So "myebay" Is Set Up Then Wait And See. Then During The Last Hour Ill Watch And Wait Until I Need To Make My Bet Like That. I Just Ran Up The Bids Cause I Was Ticked I Couldnt Get It.
Old Jan 8, 2006 | 01:49 PM
jfairladyz's Avatar
yeah I usually put a very small bid on something just to let others know that there is someone interested in the auction. Then i wait til its just about done and throw my max bid at it. You win some, you lose some, and sometime the modem stops working
Old Jan 8, 2006 | 03:00 PM
s/cL3.0's Avatar
Bleach is my Hero
Damit.. I knew I should have put 250.00 as a max not 220.00
Old Jan 8, 2006 | 05:28 PM
Ya Sc Im Depending On You To Build This Stuff. I Could But Time Is Of The Essance.
Old Jan 8, 2006 | 06:59 PM
Dorifto's Avatar
I guess it's time for me to get cracking on my ITB idea, using Honda TBs.
http://img212.imageshack.us/img212/6...ndaitb14uy.jpg
http://img212.imageshack.us/img212/8...ndaitb26ip.jpg
EDIT: Lemme guess ... this forum's got the IMG tags turned off.
noelawinslow
May 21, 2013 01:17 AM
rplytta
Aug 22, 2012 09:05 AM
ZXT83
Mar 3, 2010 07:15 PM
veyenyl
Mar 10, 2007 09:47 AM
Gilles260ZT
Mar 19, 2003 11:41 PM
