Installing piston, piston ring scoured cylinder wall
Old Sep 9, 2012 | 02:28 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
Simply put, I was installing the new pistons, which have new rings, which were installed correctly, and I have this **** going on:
IMAG0035.jpg?t=1347225966
It's mainly a mark, it barely has any feel to it, I can slightly catch my fingernail in it, but it's, still there.
Suggestions? Just go get a cylinder hone and go over it a few times?
Super Duper pissed right now, been waiting three years to start putting this motor back together, and now it goes and gets screwed up.
Also, anyone know why it would have pulled this ****?
Old Sep 9, 2012 | 05:26 PM
zero's Avatar
operator error
Old Sep 9, 2012 | 05:54 PM
Check it with a bore gauge and if need be run the dingleball through it until you can't feel it.
Old Sep 9, 2012 | 07:37 PM
Originally Posted by zero
operator error
I checked the clearance, I made sure none of the rings needed to be filed before installation, I placed them in the cylinder and checked that they all would fit
Explain where my error occurred
Originally Posted by hoov100
dingleball
Dis guy?
Old Sep 9, 2012 | 08:26 PM
So are the the rings or piston scratching? Is this the only cylinder w/ the problem?
Old Sep 9, 2012 | 08:27 PM
Dis guy?
Those work too, but I was thinking this:
They sell different grit pads too.
I don't think you had the ring compressor down all the way.
Old Sep 9, 2012 | 08:31 PM
^^^ Yup, the 3 pad / arm one is what I use. 20 seconds forward, 20 seconds backward should do it... and make sure you use WD-40!
And that fine scraped edge does look like it would be made from a ring seated improperly.
Did you use motor oil or WD-40 on the cylinder walls for the install?
Old Sep 9, 2012 | 09:08 PM
It has to be the rings, and it is the only cylinder with the issue, I even doublechecked the clearance on the rings
Make sure you use WD-40!
I had the pistons sitting in oil before I installed them, and I rubbed oil on the cylinder walls as well
Old Sep 10, 2012 | 11:39 AM
So how do the rings look on that piston? Did you align the gaps as per the FSM?
Old Sep 10, 2012 | 01:39 PM
They look fine, and they were aligned, and the gaps were all within spec
I honed it, with the assist of WD40, and this is where I'm at:
Most of the marking is gone, but the scratch itself is still there, I can still just barely catch my finger in it, so it's still there I haven't honed it for very long, short periods of 10 seconds and then I spray more WD40, a total of about 40 seconds
IMAG0037.jpg?t=1347309429
Old Sep 10, 2012 | 09:13 PM
^^^ Did you run the hone forwards and backwards? I don't see any cross hatching...
Old Sep 10, 2012 | 09:29 PM
I did, it's minimal though
I took the block back to the guy who originally did the bore and told him the retarded things that go on in my garage
He said he'll see what he can come within specs, I'm going to bring him the block, the specific piston and the rings
fingers crossed
Old Sep 12, 2012 | 04:54 PM
Cylinders are okay, no need for another overbore or sleeves
Old Sep 12, 2012 | 06:53 PM
PredatorZ's Avatar
Sigh of relief
Good to hear, I'm sure you have been stressing over that scratch for the past few days so its good to get that news. Good luck on getting her back together and running.
Old Sep 23, 2012 | 08:55 AM
83turbo280zx's Avatar
you did use some kind of lubricant when installing the pistons right? not calling you stupid. just going over basics. and also did you make sure there wasn't any carbon or dirt in the ring lands keeping the rings from seating all the way back?
Old Sep 23, 2012 | 09:06 AM
100%
Pistons were sitting in oil before installation, rings were lubed, and I lubed the cylinder walls as well
ellisdaddy917
Jun 6, 2009 09:37 AM
xlpbodily
Dec 30, 2008 06:19 PM
wgc_3
Nov 21, 2006 09:07 PM
aronjr84
Sep 29, 2002 05:17 PM
joe3z1
Mar 25, 2002 02:22 PM
