Installing piston, piston ring scoured cylinder wall
Simply put, I was installing the new pistons, which have new rings, which were installed correctly, and I have this **** going on:
IMAG0035.jpg?t=1347225966
It's mainly a mark, it barely has any feel to it, I can slightly catch my fingernail in it, but it's, still there.
Suggestions? Just go get a cylinder hone and go over it a few times?
Super Duper pissed right now, been waiting three years to start putting this motor back together, and now it goes and gets screwed up.
Also, anyone know why it would have pulled this ****?
I checked the clearance, I made sure none of the rings needed to be filed before installation, I placed them in the cylinder and checked that they all would fit
Explain where my error occurred
Dis guy?
Dis guy?
They sell different grit pads too.
I don't think you had the ring compressor down all the way.
^^^ Yup, the 3 pad / arm one is what I use. 20 seconds forward, 20 seconds backward should do it... and make sure you use WD-40!
And that fine scraped edge does look like it would be made from a ring seated improperly.
Did you use motor oil or WD-40 on the cylinder walls for the install?
I had the pistons sitting in oil before I installed them, and I rubbed oil on the cylinder walls as well
I honed it, with the assist of WD40, and this is where I'm at:
Most of the marking is gone, but the scratch itself is still there, I can still just barely catch my finger in it, so it's still there I haven't honed it for very long, short periods of 10 seconds and then I spray more WD40, a total of about 40 seconds
IMAG0037.jpg?t=1347309429
I took the block back to the guy who originally did the bore and told him the retarded things that go on in my garage
He said he'll see what he can come within specs, I'm going to bring him the block, the specific piston and the rings
fingers crossed
you did use some kind of lubricant when installing the pistons right? not calling you stupid. just going over basics. and also did you make sure there wasn't any carbon or dirt in the ring lands keeping the rings from seating all the way back?
Pistons were sitting in oil before installation, rings were lubed, and I lubed the cylinder walls as well
