Injector Swap Help
Old May 10, 2011 | 07:19 PM
BrownBomberZ's Avatar
Injector Swap Help
Ok so I have a 280zx N/A and I have recently decided to buy a new fuel rail... I have the option of a rail to work for the stock injectors, and 11mm bore rail for o-ring injectors...does anyone know a good set of 11mm injectors i can use and a good regulator, ECU, and anything else I would need to get the bigger 11mm injectors to work
Thanks
Old May 10, 2011 | 07:43 PM
There is no need to upgrade injectors on a stock n/a motor, and you'd have to do quite a few mods to need an increase of fuel.
Old May 12, 2011 | 05:01 PM
what kind of mods then cuz I am looking to upgrade alot
Old May 12, 2011 | 05:20 PM
tonsoffun300zx's Avatar
West Coast!
just get a turbo swap and go from there it's not worth it to mod an N/A especally an L28e
Old May 12, 2011 | 07:42 PM
Click: https://www.zdriver.com/forums/280zx-s130-forums-77/horsepower-heh-32606/
Bore... stroke... port... intake... exhaust... cam... ignition. Done.
Add to that:
Stand alone fuel management, $10k. Done done.
Old May 13, 2011 | 06:19 PM
well I was going to do a turbo swap cuz I found a guy selling a motor all rebuilt and cleaned for $500 but last time i called him no call back or answer so I'm still looking
Old May 13, 2011 | 08:08 PM
A turbo motor swap is always the easiest & cheapest way to make power on these cars. Unless you are a die-hard n/a fan, and have gobs of $$$ to burn, go the turbo route... and no, piecing together a turbo motor isn't a "good" alternative.
Old May 15, 2011 | 06:25 AM
i put turbo injectors on my n/a
Old May 16, 2011 | 11:51 AM
If any of you guys live in florida a hear of someone selling a complete turbo motor that is not asking a retarded amount for it let me know then cuz i have been wanting to do a turbo swap anyway
Old Jun 1, 2011 | 11:13 PM
k1drift's Avatar
just put turbo injecters, fpr and a custom fuel rail in my 79 n/a. should be finished with it tomorrow.
Old Jun 2, 2011 | 12:44 AM
you planning for nitrous? Or installed it because you think it will give you more power?
Old Jun 7, 2011 | 03:24 PM
k1drift's Avatar
nope. just needed to get the car running right and a buddy of mine had the parts i needed but off a turbo car. also did the dizzy, mass air flow and timeing. she runs like achamp now. getting it ready for boost
Caelenz31
Jan 2, 2015 03:56 PM
datdude407
Sep 13, 2010 09:44 AM
FubarI33t
Aug 18, 2006 08:18 AM
OutLAW Z
Apr 30, 2004 07:25 AM
hellzbellz83t
Sep 18, 2003 05:52 PM
