idle issue
Old Sep 14, 2011 | 09:59 PM
Lupe's Avatar
idle issue
Ok so not so long ago i blew my headgasket and i replaced it but ever since its been idling funny idk if i flipped some wires ir something. When the car is cold it idles low like 600 then as its warming up its starts creeping up eventually reaches 1600rpm so is there any way i might have mesed anything up.
@fric frac HAPPY???? lol
Old Sep 15, 2011 | 10:43 AM
Could be a vacuum leak, mis-adjusted TPS, mis-adjusted idle screw, non-functioning air regulator...
Check those for starters.
Old Sep 17, 2011 | 09:10 PM
Lupe's Avatar
I checked the vaccum lines and found one that doesent seal as good and can hear a hissing around it it sems that the hose is allitle bigger. i replaced it and helped allitle now it only goes to 1500.The idles swrew is turned all the way down and i did install a new tps and tried messing with it but cant get right.
Old Sep 18, 2011 | 03:43 PM
Are you running rich perhaps? Try taking your AFM apart, and leaning it out. Turn the gear clockwise. But be careful when you loosen the phillips screw, that you don't let the gear come undone. Try that and get back to us. There is also a write up on how to rebuild your AFM. It is a sticky on these forums somewhere. Good luck man.
Old Sep 18, 2011 | 09:54 PM
Lupe's Avatar
Do i take it apart from the bottom or from the side cus the side cover is siliconed on i guess the previous owner lost the screws or something. My AFM has a adjusting screw on the is that used to adjust the mixture?
Old Sep 20, 2011 | 05:04 AM
https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/js-how-rebuild-your-afm-15277/
Here you go man, this is the link to rebuilding your AFM. If you still have questions after reading it. Feel free to ask. Good luck.
Last edited by WildmaN; Sep 20, 2011 at 05:08 AM. Reason: Changed the link to help thread
Old Sep 20, 2011 | 04:35 PM
Lupe's Avatar
ok ill give it a try ill keep you guys updated thanks for the link wildman
Old Sep 22, 2011 | 11:03 PM
Lupe's Avatar
So i Readjusted the plate on the afm and still the same still running supper rich now im starting to think bad fpr so ima go ahead and order one and see what happens
Old Sep 23, 2011 | 11:42 AM
^^^ instead of guessing, you could always verify it first. Just hook up a fuel gauge.
Old Sep 25, 2011 | 09:50 PM
Lupe's Avatar
well my fpr has a guage on it and it reads really high some times and low so i just replaced it its running fine now i thanks for the help guys
madkiwi
Jun 6, 2015 07:40 AM
RaTT92
Dec 10, 2010 12:17 PM
kiboy6
Dec 13, 2008 01:53 AM
fufaso
Nov 4, 2007 10:02 PM
skittle
Feb 18, 2007 01:04 PM
