Idle Issue....
Idle Issue....
It seems like either my gas pedal or choke is sticking. When I start 'er up she is fine, but then after driving for a little bit and I come to a stop, the engine is idling higher than normal, when I give it a little gas (in neutral or with the clutch in) the idle level drops down to normal.
Anyone know what's going on here and if it is an easy fix I can do on my own?
This is for my '74 260.
Thanks!
Thanks!
Did you figure it out?
Most of the time I have this issue, it's more of a lean condition. You get the idle to stay low when cold, but when hot it wants to rise higher and higher. Sound like your problem?
Just curious to know more about it.
Hey yeah thts me i start out at a cold idle at around 500 rpm and it smells like gasoline and then after heating up i idle around 800 also, i'm leaking coolant around a hose...see picture....but what's goin on?!
madkiwi
06-06-2015 07:40 AM
kiboy6
12-13-2008 01:53 AM
