I Got No Pulse !!!!!
Old Aug 9, 2003 | 07:13 PM
duckyz's Avatar
Well, like most things, this could be a number of problems. In my case it was because the car had been sitting............wait, you said no pulse. As in the injectors aren't firing? -or- as in the car is dead, no worky?
Only reason I ask, is that's two seperate problems and I don't want to give you a long dissertation on the wrong fix.
Old Aug 13, 2003 | 08:25 PM
duckyz's Avatar
Hey Bleach!!!!!!!!!!!!!! This guy needs some help!!!!!!!!!!!!!
Sounds like the FI CPU is bad to me..... could be your fuel filter or fuel pump also....just a guess
Old Aug 14, 2003 | 10:58 AM
What I want to know is, where in your Nissan manual does it say to give the injectors a good whack!?! hehe...
I'm glad you got the problem solved. Now check your ground connections, and I've only heard good things about running extra ground wires (smaller) from the engine block/head or whatever to the frame or body.
Old Aug 14, 2003 | 04:26 PM
Skully's Avatar
and WHAT did i tell you?
DID YOU HOOK ALL OF YOUR CONNECTIONS BACK UP!!!
"uhh...yes...uhhh" :P
zstreet86
13
Jul 17, 2020 03:35 PM
craracer05
Sep 17, 2014 07:14 PM
rocketknight03
Sep 11, 2010 09:27 AM
KasbeKZ
25
Mar 5, 2008 06:34 PM
QbanZ
Jan 6, 2005 07:15 PM
