I Got No Pulse !!!!!
ok i took out the injectors gave them a whack with a socket extension bar put them back in (had pulse before)
Cranked it over and she fired up touched the accelrator reved up too about 3k and died What the **** happened ? i got no pulse now someone please help :) |
Well, like most things, this could be a number of problems. In my case it was because the car had been sitting............wait, you said no pulse. As in the injectors aren't firing? -or- as in the car is dead, no worky?
Only reason I ask, is that's two seperate problems and I don't want to give you a long dissertation on the wrong fix.:cool: |
No pulse to the injectors.. i only get a very very very very weak flicker on #5 cylinder :(
Hey Bleach!!!!!!!!!!!!!! This guy needs some help!!!!!!!!!!!!!
Sounds like the FI CPU is bad to me..... could be your fuel filter or fuel pump also....just a guess |
Problem solved.
2 things i found. 1. connection off the battery terminal dont know if it made any diffence. 2. Fuse blown replaced 5 of them because the Japanese Box i didnt know which was which. |
What I want to know is, where in your Nissan manual does it say to give the injectors a good whack!?! :D hehe...
I'm glad you got the problem solved. Now check your ground connections, and I've only heard good things about running extra ground wires (smaller) from the engine block/head or whatever to the frame or body. |
and WHAT did i tell you?
DID YOU HOOK ALL OF YOUR CONNECTIONS BACK UP!!! "uhh...yes...uhhh" :P |
