I don't understand!!
Old Jun 3, 2003 | 05:32 PM
lifegrddude's Avatar
Externally Wastegated
Don't feel bad, I'm 22 and still learning!
If your car has had head work and a beefed up motor, I'm pretty sure they used higher compression pistons in your motor. I'm guessing either 8.5:1 or 9:1. Bob Sharp was well known in the racing world so I'm sure he had a reason for upping the compression on your turbo car. Most likely to reduce turbo lag and off boost driveability. The redesigned combustion chamber could also affect compression ratio too and increase efficiency. If the pistons and rods, etc are all forged, your motor will last forever and a day as long as you don't lean out and hit detonation.
Compression Ratio: Ratio of combustion chamber to cylinder volume + combustion chamber. (got that from Ray Hall Turbocharging) Compression in the cylinder shows relative health of the motor when stacked up to the factory specs. You could do a cylinder leakdown test to see how much blowby you're getting.
John 82ZXT
viasloth
Jan 23, 2012 03:46 PM
the_journeyman
Sep 13, 2011 06:39 PM
Thaddeus280
Mar 13, 2007 11:44 PM
RodMoyes
Feb 13, 2006 12:41 PM
