How to keep motor running???
Old Aug 1, 2005 | 05:14 PM
davidjoe007's Avatar
Did you check the fuel damper?
Old Aug 1, 2005 | 05:28 PM
I think though you need to look at the pressure regulator as you culpret. The FSM says. "The pressure reugulator controls the pressure of fule so that a pressure difference of 250.a kPa (2.55 kg/cm2, 36.3 psi) can be maintained between the fuel pressure and intake manifold vacuum. The pressure regualtor is divided into the air chamber and fuel chamber by the diagram. Intake manifold vacuum is introduced into the air chamber, thereby keeping differential pressure contrant causing excessive fuel pressure constant, causing excessive fuel to return to the fuel tankthrough the return side port. This constant differential pressure provides optimum fuel injection in every mode of engine operation." and I think the last sentence is the key for you. If there is no vacuum or if the pressure relator isn't working it would affect it in this way. Hope this works for you.
davidjoe007
Jun 29, 2021 04:45 PM
Z31_john
Nov 6, 2009 06:56 AM
81s280zx
14
Oct 7, 2005 10:48 AM
fattyjay22
Mar 12, 2004 10:28 AM
John300
Oct 12, 2002 10:17 PM
