hooked cables up backwards and now 280zx wont start. please help
Old May 9, 2006 | 05:00 PM
chrischicoine18's Avatar
Thumbs down hooked cables up backwards and now 280zx wont start. please help
i just purchased a 1983 datsun 280zx. the only problem was it needed a batery,but it ran great.i flaged someone down to give me a jumpstart to go get a battery. a guy in an older truck had stopped to give a jump. so i hooked up my cables correctly and got in the car. i tried to start it and it wouldnt turn over but it did try to crank. then i saw a little smoke come from near the batery, so i stoped. i got out and noticed the guy hooked his cables up backwards. i checked and noticed it fried a fuse link near the batery. i replaced the fuse link and the batery, but the car still will not start. it sounds like a car that is out of gas. i was wondering what is wrong. i thought it could be the computer or maby burnt the fuel pump. but i dont know too much about datsuns and i dont have moneyto fix the wrong parts. thank you for the help. now
Old May 9, 2006 | 05:16 PM
It's quite possible that it fried the ECU. Pull the coil wire off at the distrib & check for spark... if so, pull a spark plug to see if it's wet (fuel soaked). If not, start checking the ECU. Or... if you have a spare ECU, swap them.
Old May 11, 2006 | 09:32 AM
Mrchilders's Avatar
Yep I do think you fried ythe ECU/ECM
If so I have a box full of good ones I no longer need about 10-15 plus and you can have the whole box for 50.00
Old May 11, 2006 | 01:51 PM
PooFlinginMonke's Avatar
Fuse links?
Maybe the diode between the igntion switch and who knows where?
Old May 12, 2006 | 10:18 AM
Mrchilders's Avatar
Question 280Zx
Yes Fusable links right in front of the Battery ,Under the Plastic dome looking item mounted on the fender well.use a jumper or a DVM.But if you are a Zdzr you would think that upon see the cables backwards the very first thing to do was see if the fuseable links feel mushy
280zman
Jan 24, 2013 01:31 PM
moorebl
Apr 14, 2011 03:28 PM
81na280x
Jun 17, 2009 10:31 PM
driftracer300z
Jan 28, 2009 09:03 PM
gold280zx
Aug 21, 2004 09:01 PM
