help please rev limmiter 2000 rpms?
Old Nov 5, 2006 | 06:34 PM
wake2wake's Avatar
Question help please rev limmiter 2000 rpms?
280zx 1983 na every thing was good until i got up this morning my car wont dgo above 2000 rpms. not because of it badly running but more like a rev limiter right at 2000. any ideas please help
Old Nov 5, 2006 | 06:45 PM
tps sensor has moisture in it. did anything happen other than night fall that you may or may not be aware of? like really heavy rainfall. or washed out the engine bay, or drove through a puddle earlier that day. check also for loose connections on the engine. think and report back.
Old Nov 5, 2006 | 06:49 PM
wake2wake's Avatar
actually i know this sounds stupid but i havnt had a hood on it for a few weeks and it rained again last night? iv power washed the whole engine before and havnt had a problem where is the tps sensor
Old Nov 5, 2006 | 07:07 PM
the little box on the throttle body, i would seriously get something over that motor, even if its a beet up, rusted, dented, crappy hood, it WILL save your ***..
Old Nov 5, 2006 | 07:10 PM
wake2wake's Avatar
thank u guys very much
Old Nov 7, 2006 | 09:27 AM
007max's Avatar
From NY to AZ
That moisture sensor is sure a PITA. I washed the car one night and then couldnt get going faster than 45 in 5th the next day. Is there any way to disable it or dry it out quickly if this happens again?
Old Nov 7, 2006 | 09:34 AM
Just disconnect it & blow it dry w/ compressed air, let it air dry, or spray it w/ WD40. Then apply some di-electric grease.
Old Nov 7, 2006 | 04:07 PM
jfairladyz's Avatar
Thats the key right there if you dont the headache coming back time and time again.
Also using some shrink wrap or electrical tape to seal off the connector boot where the wires enter if the boot is rotting away from age. That thing needs to be sealed as well.
mryuri
Dec 27, 2013 05:31 PM
JCastro2866
Feb 2, 2012 01:00 PM
ramjv
Sep 9, 2010 11:23 PM
KevinH
Aug 15, 2006 09:50 AM
elementsofway
Jun 2, 2006 09:29 PM
