Help Getting the timing down while assembling
Old Jul 15, 2008 | 01:42 PM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
Okay, I DO have a Haynes and have read all pages on on the engine section searching cover to cover, but I can't find anything on setting the camshaft back to 1. What I mean by that is, I've set the bottom end to TDC, but I need to figure out how to put the new head I bought on with the timing down.
My question is, I took a picture of the head, and I'm wondering if the valves are in the right position, and can I put it on the way it is? I took a picture of the #1 chamber's intake/exhaust valves, and their lobes.
tell me if you need pictures or more information, I'm just sitting here playing solitaire waiting for results...I really can't wait to get this all together tonight!!!
Old Jul 15, 2008 | 02:00 PM
As long as the valves are closed on the cylinders that the piston is at TDC (1 & 6), you are fine. You can set the cam to the correct location by putting on the cam sprocket in #1 location, and set the chain DOT to about 2 o'clock. There's a pic in the Haynes manual of the timing chain markings... I'd tell ya the page but I'm at work & my Haynes manual is not.
EDIT...
Here:
Old Jul 15, 2008 | 03:59 PM
1&6 are at TDC, 1's valves are closed, but 6's exhaust is completely opened. I think that makes since though, because aren't they supposed to be on opposite strokes? well i'm putting it together anyways...
Old Jul 15, 2008 | 04:16 PM
In case you missed it..........
Set the cam, then put the head on.
Old Jul 15, 2008 | 09:01 PM
280zx2by2's Avatar
Haterade by da gallon!
nismo(or anyone) do you have scratces on the top of your valve cover like the timing chain is rubbing on the cover?if not i think someone put the wrong chain on my car....
Old Jul 15, 2008 | 09:23 PM
It's more likely that the chain is loose.
Old Jul 15, 2008 | 10:32 PM
280zx2by2's Avatar
oh **** thats not good at all .... now i got something to do on the car!!!! i think... its simple right... just tighten the tensioner
i know i know go search for it... and i will sometime this week
Old Jul 16, 2008 | 06:31 AM
Let me know how it goes adjusting a hydraulic tensioner. Pull off the valve & press in on the chain to check tension. It should feel tight & move slightly. Also... when you are driving, do you hear any rattle or "metal on metal" sounds?
Old Jul 16, 2008 | 10:53 AM
280zx2by2's Avatar
i did touchey feely thing and it felt good like it wasnt going to fall or slip off(thats why i was thinking it may have the wrong chain)
i hear a clicking sound wich may just be my valves but that dosent explain the scratches(the scrathes arent deep, its just were the chain has rubbed)
Old Jul 16, 2008 | 11:42 AM
Maybe the chain WAS loose and the previous owner fixed it....
Old Jul 16, 2008 | 08:44 PM
280zx2by2's Avatar
MABE... lets hope... if i start to not post anymore then you know what happened
Old Jul 16, 2008 | 10:42 PM
Alright, I pray to God I did this right. I seriously spent all of last night and this morning for 2 hours cleaning the gasket off the front cover. I didn't scrape off a bit that was bigger than 5 mm, it was the most frustrating thing i've ever done in my life.
But I did what you said, I rotated the camshaft, set it at 1 and put the timing on. The bottom was at TDC when I put the head on. I had the timing wheel from the P90A and it was considerably not on as much on the P90. But I torqued it down to 102 ft/lbs which was WOW. I'm terribly scared that when I start it it's just going to blow up on me. I also included a picture of the water pump i'm reusing if you have any input...but yeah what have i missed?
P.S. i took these pics with my phone. I'm pretty impressed!
Old Jul 17, 2008 | 06:16 AM
Nice camera phone pics! Though I can't see the "bright" link on the chain that is supposed to line up w/ the cam gear dot. Is it?
Old Jul 17, 2008 | 08:15 AM
280zx2by2's Avatar
ahh i cant wait till i move out of moms and dads house and i can pull my engine out and give it all the TLC it deserves....
Old Jul 17, 2008 | 09:29 AM
No....I didn't think that the bright link mattered, since I took it all apart anyways...DOes this mean that I have to take it all apart and make sure the bright chain is on the #1 thing?.....
Old Jul 17, 2008 | 09:42 AM
Technically it doesn't matter where the bright link is, as long as there are 42 link pins between the crank sprocket marker and cam sprocket marker (I SUGGEST LOOKING AT THE REFERENCE PIC I POSTED ABOVE... STUDY IT FOR A LONG TIME).
Did you pay attention when removing the cam sprocket, to which link was lined up w/ the cam sprocket dot?
Old Jul 17, 2008 | 10:05 AM
yeah i marked them both down when I was removing the cam sprocket. the number 2 and number 3 links I both marked, but since I bought a new head and such all my notes were kind of rendered useless...I'm pretty sure there's 42 link pins between them, because it is as tight as it can go, and the tensioner is in there, I'm 100% of that.
Old Jul 17, 2008 | 01:15 PM
Oky last question I'll ever bug you guys EVER i promise!! Okay I've done everything with the timing belt and the LAST thing I need to know is how the #)($* do I get the distributor and oil pump back on right?!?? I read the haynes and all it says is make sure the punch mark and oil hole are lined up before I install it, but what do I do with the distributor!?!? I've googled it, and read the FSM as well, but I'm stuck. LAst question ever!! How do I get the oil pump and distributor worked out?!?
Old Jul 17, 2008 | 01:38 PM
Read this (yes... it's a 3L stroker, but it talks about putting everything together): http://www.geocities.com/inlinestroker/index.htm
The rotor should be pointing almost exactly straight forward to the front of the car.
Old Jul 17, 2008 | 03:33 PM
and the point is between the 2 and 5 spark plugs. is that right? I dont' really understand what that picture means,
"If done correctly the shaft tang should be at the 11:25 position and directed tangent to the backside of the top distributor-adapter mounting bolt. "
does anybody know what that means?
Old Jul 17, 2008 | 03:40 PM
Ya know these things called "clocks" ? Ever heard of them? Where would 11:25 be on a clock??????
Old Jul 17, 2008 | 04:17 PM
okay that's that...
how do i match up the distributor side? That's all i need! :-)
while i wait, i'm putting the head bolts on then all i have to do is put everything else on which should be pie.
Old Jul 19, 2008 | 02:44 AM
Okay just a little update for you nismo and anyone else who might ever have this trouble...
In the FSM it shows exactly what position the oil pump shaft should be in and mine was pretty close, i'll probably have some timing issues, but I got the distributor all figured out. Then I torqued in the camshaft, but bent a screwdriver and scored the top of the head :-/....but i think it will be okay. And i just finished putting the oil pan back on so Tomorrow is the left side of the engine and then the adventure of figuring out the harness!!
Old Jul 19, 2008 | 04:12 PM
There's no "close" about it. If the motor is at TDC, and you've aligned the pump shaft right, it will line up correctly & with the distrib on, the rotor will point to the front of the motor. If you have it one gear off either direction, it will be noticeable. And... if you don't have it correct now, and find out once the motor is in and try to start it, you will regret it because correcting it later sucks!
sidneyam
Feb 21, 2011 05:51 PM
Datsun_Husky
Nov 17, 2010 05:48 AM
Fast240Z
May 25, 2005 11:13 PM
DoTheDrew888
Apr 10, 2005 01:12 AM
Zmedic
Jul 20, 2001 01:26 PM
