heater issue
Old Feb 19, 2012 | 04:40 PM
stephen king's Avatar
heater issue
hi folks i am a new owner of a 1979 280zx the heater lines have been cut and pluged and as i suspected the heater core leaks . my question is this there is a brass tee on one line that has like a t stat in it there is no hose comming off it and i have no idea where it would lead to any help would be appreciated as to what this is and where the heater hoses go to thanks
Old Feb 19, 2012 | 05:26 PM
Welcome to ZDriver!
You mean this?
http://www.thezstore.com/page/TZS/PROD/16-7648
There are two heater hoses going through the firewall that connect to the back of the cylinder head & water pump outlet.
First step is to buy the Haynes manual or download the FSM for free at www.xenons130.com/reference
Old Feb 19, 2012 | 07:24 PM
there are two hoses from fire wall one has a 90 degree turning down to the plug put into the block the other hose runs along the engine to the water pump that it the hose that has the tee the tee is actualy upside down so the hose has a straight shot from the water pump the tee points stright up with the t stat or dump valve but no hose was atached to it
Old Feb 19, 2012 | 07:32 PM
Sorry bro... I think you need to use a few periods (.) in your sentences so I can understand you.
Can you post a pic of what you are talking about?
Old Feb 19, 2012 | 07:55 PM
i took the tee out here are the pics. i think i have std. ac i see at the z store the the control for me is not avalible i wish i could see a pic of mine it looks like a hose ataches to the top of the control valve
Attached Thumbnails heater issue-280zx-005.jpg   heater issue-280zx-006.jpg   heater issue-280zx-007.jpg
Old Feb 19, 2012 | 08:35 PM
Here ya go... From the FSM you can download from the link I posted.
Old Feb 19, 2012 | 08:51 PM
looking at this picture. the tee mecinsim looks like it sits in the middle. it also looks like it ties back in where it goes into the block. right now there is just a plug in the block i will need to find that y that mounts into the block any ideas
Old Feb 19, 2012 | 08:56 PM
I have a spare somewhere... might take a few days to find.
Have you checked your local junk yards to see if there are any 280zx's?
Old Feb 19, 2012 | 08:58 PM
GTR's Avatar
GTR
Badass Z Chick
are you refering to the "T" that's been circled?
Old Feb 19, 2012 | 09:12 PM
yes the tee ibelive is circled in reality its a littel closer to the left. as far a junk yards we have a couple i hope they are open tomarrow. i just got the car saturday. i will let you know if i cant find one here locally. thank you soooo much for all your help
Old Feb 19, 2012 | 09:13 PM
GTR's Avatar
GTR
Badass Z Chick
If not I'm sure i have a couple of those laying around too ^_^, k?
Old Feb 20, 2012 | 04:28 AM
OmEgA's Avatar
......... lmao
Old Feb 20, 2012 | 10:46 PM
went to the junk yard today got a lot of stuff, including heater core, what a job to get that out, there has to be an eaiser way. got the heater part off the block got tail light. headlight boot, seat belt and a bunch of other goodies. what king of presure should i test the heater core up to? also which is easier the pull the dash and cross bar or ac unit and fan?
Old Feb 21, 2012 | 01:34 PM
The radiator caps are rated at 12-15psi... no need to go above that.
Pull the dash and cross bar. It's easier than contorting your arms and working upside down. And we even have several "dash pulling" write ups.
Old Feb 21, 2012 | 06:55 PM
The first dash pull is a little daunting but it's really not that bad. After that you're a pro and you could probably pull the whole dash out in half an hour...
Old Mar 1, 2012 | 03:55 PM
well put in new pressure tested heater core. i guess the,heater core was ok. i think its the controll valve. i have ac and the z store dosent have one for th e79zx with ac any suggestions
Old Mar 1, 2012 | 04:29 PM
Didn't you get the control valve when you went to the junk yard?
You can also buy it from Nissan.
Old Mar 1, 2012 | 05:56 PM
it was alrady gone. what year uses the same valve, there is an 80 next to the 79 i pulled the heater core out of
Old Mar 1, 2012 | 10:24 PM
Man I can't believe you guys have Z cars in the wreakers still.... nice
Old Mar 2, 2012 | 10:48 PM
stupid question how ca n i tell if my water **** has auto air conrtol. my car has ac and i need to find a new heater control ****
Old Mar 2, 2012 | 11:08 PM
The auto climate control water valve is vacuum controlled. The manual a/c is not:
http://www.thezstore.com/page/TZS/PROD/16-7645
Old Mar 2, 2012 | 11:25 PM
thanks sooo much
Sunny_z32
Jan 8, 2014 02:06 PM
skygunner58203
Aug 28, 2012 04:17 AM
skittle
Dec 28, 2009 06:22 PM
VandiL
Feb 18, 2006 11:37 AM
thomas schuchat
May 25, 2003 12:41 AM
