Headlights and parking lights...help
Old Mar 15, 2005 | 03:18 PM
lwb50llb23's Avatar
Hey, I am new here. I have a 1981 280zx 2+2. The headlights and the parking lights have gone out. I have brake lights and turn signals though. Do you have any idea why this may be? I have checked the fuses but still no luck. Any help would be greatly appreciated. I can't drive at night or in bad weather which we are supposed to have 3 or 4 days of coming up this week. Thanks.
Old Mar 15, 2005 | 04:30 PM
icice9's Avatar
Super Siver & Black Stud
very common problem with the z check the fusable links on the car.. theyre located right next to the bat. its a lil black box thats attached t the side.. also check your relays.. if all else fails.. rewire it...
Old Mar 16, 2005 | 01:44 PM
Mine still does that intermittenly. I'm pretty sure mine is a weak connection around the steering column. When I hit the steering cover from underneath, sometimes the lights come back on. Could be the switch itself too.
Old Mar 16, 2005 | 02:40 PM
lwb50llb23's Avatar
Thanks for the info, will try and see if I can get these things to work. Thanks again, by the way do you know if after the relays there is a headlight sensor, at least thats what the book said. You ever had any trouble with them?
Old Mar 30, 2005 | 09:22 PM
Cw2435's Avatar
it is the switch it was happening to mine and i went and got a new switch from a z yard and it has solved the problem they don't shut off and u can switch from regular to brites it will solve all your problems i'm pretty sure.
Old Mar 31, 2005 | 06:19 PM
mattduskater's Avatar
I had the same thing happen to me. The fuzeable link next to the battery started on fire and burnt the wireup! but luckly I was standing there looking under the hood when it hapend
mark86t
Jan 30, 2007 10:11 AM
alex
Oct 18, 2004 05:06 AM
entropy31
Aug 20, 2003 02:58 AM
trivan
Jul 8, 2003 05:40 PM
gjblue55
May 30, 2002 07:48 AM
