gears grinding =0\
Old Oct 3, 2004 | 11:16 PM
B1nAryVilE's Avatar
gears grinding =0\
well i've been having a problem with my car. I recently started grinding gears a while back so i decided to check it out and i figured it was either the slave or master cylinder that was messing up so i went on and replaced both. Some how i still have the same problem but the weird thing is i grind gears only when the engine is in the hot heat and when it's cold persay the morning i have no problems with the gears any suggestions on what's going on? thanks for the time fellas.
-chuck
Old Oct 4, 2004 | 08:20 AM
roninjiro's Avatar
im having the same problem with my firebird, i would like to get an idea of what is going on as well. sry chuck, havin same problems
Old Oct 4, 2004 | 09:19 AM
When the transmission fluid is cold, it is thicker and resists the grinding. The problem is your syncros going out inside the transmission. It'll get worse and worse and then one day it won't stay in gear.... but I got another 70K miles out of mine before that happened.
Old Oct 4, 2004 | 04:21 PM
B1nAryVilE's Avatar
well is there any way to prevend further problems? or should i just get a new tranny?
-chuck
Old Oct 4, 2004 | 05:05 PM
icice9's Avatar
Super Siver & Black Stud
you can slow down the process by cheanging your gear oiul but it will eventually go out on you.. remember thease cars have 20 year old transmissions in them... you might wanna try changing your oil to synthetic...
Old Oct 4, 2004 | 05:35 PM
Skully's Avatar
yeah mine was grinding bad too....whenever i would shift fast it would grind...but when i changed the clutch n pressure plate and bearing slave and master cyl. and put new oil in im not sure it probably was synthetic....it runs way smoother now...i know my synchroes are still worn out but it doesnt grind anymore even when i drive hard....
Old Oct 4, 2004 | 06:18 PM
B1nAryVilE's Avatar
thanks guys that really helped no more gear grinding =0)
-chuck
Old Jan 5, 2005 | 05:26 PM
newb81280zx's Avatar
I'm having a similar problem except it grinds (mostly 2nd gear) when the car is still cold then after I drive it awhile it seems to shift smooth. Any ideas?
Old Jan 5, 2005 | 09:13 PM
lww's Avatar
lww
Head Muckraker
-chuck
Just out of curiousity, which of the suggested changes made the grinding go away?
Clutch n pressure plate? Bearing? Slave and Master cyl.? New oil? Change to Synthetic?
Old Jan 5, 2005 | 09:42 PM
Its probably the same thing. Syncros going out. 2nd gear is commonly the first gear to go. As far as shifint smoothly once warmed up; I'm not sure why.
Change your transmission oil every 30,000 miles and shift slow... and start saving for a rebuild.
Old Jan 6, 2005 | 06:21 AM
DoTheDrew888's Avatar
What is involved in a tranny rebuild? Is it something I could do myself?
Old Jan 6, 2005 | 08:16 AM
assimilated420's Avatar
i wouldnt recommend it if you dont know transmissions real well.... cuz the slightest mistake and your screwed....im not sure all the processes involved, im just know like gear replacements, bearings and small pieces and various parts and refinishing of others...
i would get it done professionally...that would be my advice
Old Jan 6, 2005 | 08:48 AM
280gty's Avatar
Anyone know how much it would cost to rebuild or replace the transmission?
I'm new to driving a stick & found out that I had to "double-clutch" to shift gears sometimes especially downshifting...really annoying..but most people say they just bear with it until forced it gives out.
I'm talkin' about the cost of a top notch job... or new parts...not sourcing junkyard parts....cause I need everything to work perfectly & I don't like taking chances. :rofl:
Old Jan 6, 2005 | 09:22 AM
I paid $375 for a low-mile Borg Warner T5. 66,000 miles
I've heard rebuilds for the Nissan transmission are $200-500.
Old Jan 6, 2005 | 10:23 AM
280Z4ME's Avatar
I had my tranny rebuiltin casper when my clutch went out.it cost me 500 for everything.
Old Jan 6, 2005 | 01:07 PM
lww's Avatar
lww
Head Muckraker
I can walk into the tranny shop in Hayward and pick up a freshly rebuilt B/W T5 for $600. I drop off my old one and walk out the door.
Old Jan 6, 2005 | 02:18 PM
280Z4ME's Avatar
That was for the tranny R&R rebuild and new clutch, flywheel and pressure plate. We are talking about Casper Wyoming. Not Hayward Cali. In Wyoming there might be 100 Z,s in the entire state. In Cali it is a hell of a lot higher and easier to get parts. I had to wait 3 days to have parts delivered out of MSA.
Old Jan 6, 2005 | 03:19 PM
icice9's Avatar
i love living in hayward!!! theres like z's all over here... in fact theres 3 other 280ZXs like mine driving around...
Old Jan 6, 2005 | 07:40 PM
...but not quite as nice as yours! :hpydance:
tennisman93
Nov 6, 2011 08:59 AM
BlueKitsune
Jul 18, 2009 10:41 PM
Turbo86
Sep 8, 2007 02:33 PM
lightspeed
12
Jan 3, 2005 09:03 AM
My Fairlady Z
Sep 15, 2004 05:40 PM
