Fuel Rail Removal
Old Sep 29, 2012 | 10:19 AM
noyb43's Avatar
Fuel Rail Removal
"attempting" to pull the existing fuel rail so that I can clean the injectors, replace all the seals, and replace all the wiring harness connectors to the fuel injectors. New connectors received from FricFrac...thanks!
Now, what is the easiest way to get the fuel rail mount off behind the idler pulley, without having to actually removal that darn pulley? Those bottom bolts are a bear to get to!
Secondly, once I do get this accomplished, what is the best recommendation for cleaning the injectors while they are out?
Thanks for all advice received.
Old Sep 29, 2012 | 03:05 PM
Use two nuts back to back to remove that stud holding the fuel rail & pulley together. Upon install, use a proper size bolt instead of that stud.
Lots of info on the intrawebs about DIY injector cleaning:
Google search - Injector Cleaning
Pez
Feb 9, 2015 04:27 PM
ericeel
May 25, 2014 10:29 PM
83ZXGurl
Jan 22, 2012 03:23 PM
SHADY280
Mar 8, 2006 04:30 PM
