Fuel Rail Removal
Fuel Rail Removal
"attempting" to pull the existing fuel rail so that I can clean the injectors, replace all the seals, and replace all the wiring harness connectors to the fuel injectors. New connectors received from FricFrac...thanks!
Now, what is the easiest way to get the fuel rail mount off behind the idler pulley, without having to actually removal that darn pulley? Those bottom bolts are a bear to get to!
Secondly, once I do get this accomplished, what is the best recommendation for cleaning the injectors while they are out?
Thanks for all advice received.
Use two nuts back to back to remove that stud holding the fuel rail & pulley together. Upon install, use a proper size bolt instead of that stud.
Lots of info on the intrawebs about DIY injector cleaning:
Google search - Injector Cleaning
