Flywheel question...
Old Jun 20, 2004 | 06:46 AM
hellzbellz83t's Avatar
Are the flywheels the same for NA 5 speeds and turbo 5 speeds? I fond a 17.5 pound flywheel from a Maxima. The guy says it will fit the Z and ZX cars. Before I get it I just want to be sure it will work on my turbo 5 speed.
Thanks!
-Kel
Old Jun 20, 2004 | 10:00 AM
FastZ's Avatar
Did it come off an L-series or vg30 maxima? They did make both. So you might want to find that out.
Old Jun 20, 2004 | 11:23 AM
Says it's a Y70 flywheel and should fit any L-series motor, including any '70-'83 Z or ZX. I just wanted to be sure.
-Kel
Old Jun 21, 2004 | 04:30 PM
The real question is, what is the diameter of the turbo clutch? This flywheel will only accept the 225mm clutch. So, will it fit a turbo or not?
Thanks,
-Kel
Old Jun 21, 2004 | 09:55 PM
FastZ's Avatar
If i remember correctly that is the 2+2 clutch, which supposedly is the same as the turbo. Not to sure. I think the 2 seater clutch is 205. Will have to look for my invoice.
Old Jun 22, 2004 | 08:57 AM
The Maxima uses the smaller flywheel contact patch and clutch. 225mm
the ZX 2+2 and turbo use the 240mm flywheel and pressure plate and stronger clutch fingers.
I don't think you want to use the Maxima flywheel. They came on an L24. Maybe if you resurface it then your clutch will do fine. I'm not sure.
Old Jun 22, 2004 | 08:53 PM
FastZ's Avatar
My bad he is right. I knew they were different sizes. Just could not remember what they were. If you order a clutch or pressure plate find out which flywheel you have. These are different between the 2.
Old Jun 23, 2004 | 08:37 AM
...are you talking about this thread or the other thread about the grinding 2nd gear. I don't remember any comments on labor or how hard it is to replace. We're just talking about parts right now.
Old Feb 17, 2005 | 04:58 PM
DoTheDrew888's Avatar
I know this is an old thread but I just want to clarify. The 280ZX 2+2 and 280ZX turbo flywheels are the same size right? Also, im pretty sure this isn't a problem but the larger flywheel will bolt into the smaller flywheel location without any problems, correct? I'm considering buying a lightened flywheel from Victoria British and I need to make sure the turbo flywheel will work on my 2+2. Thanks a lot guys.
Old Feb 18, 2005 | 09:06 AM
The flywheels are the same size overall. The contact surface area is either 225mm or 240mm wide. (circle)
A 225mm flywheel from a NA car will bolt onto a 2+2 or turbo, or 2+2 turbo. You will just have a slightly weaker clutch.
The turbo flywheel itself weighs more. I've never heard of a lightened turbo flywheel. If it is lightened, it probably started as a 225mm contact flywheel.
Just make sure your clutch kit you put on matches the contact width. That's the only thing to worry about. eBay has 240mm clutch kits all over the place. The 225mm kit you have to buy from a store.
Old Feb 18, 2005 | 02:07 PM
Actually I only know of one place that makes them for anything other than the Turbo 280ZX (or 2+2). All the other flywheels are the 240mm version. Here are some ebay links if anybody is interested in buying a lightened flywheel.
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WD1V
BLKzxTT
Mar 28, 2014 09:20 AM
Anferno
Aug 12, 2013 11:34 PM
KolboltKandyZ
FS: 300ZX (90-96)
May 25, 2013 03:01 PM
metatron
Nov 24, 2011 05:59 PM
sion
May 4, 2006 04:26 PM
