Electrical Problem-Please help
Old Oct 19, 2008 | 09:59 PM
zfanman's Avatar
While looking at a 280zx that I'm interested in buying, I noticed that the temperature guage, the side mirrors and the A/C do not work. Few minutes later while cruising they started to work suddenly. The next day, I drove the car again, and the same problem happened but they didn't work until the end of the ride.
Is this a major problem with the car wiring and how expensive is it to fix?
Thanks for the help.
Mike
Old Oct 19, 2008 | 10:05 PM
Moved to 280ZX Performance / Technical
Have you checked the fuses, main wiring blocks under the dash, and fusible links?
Old Oct 19, 2008 | 10:09 PM
if it has glass fuses, they could be broken, not blown. then when they contact when hitting a bump they work. had that happen once. verify with a test light. could even be a bad ground on the car somewhere. its gonna take some looking.
Old Oct 20, 2008 | 04:28 AM
lww's Avatar
lww
Head Muckraker
Wiring problems are only expensive if you don't trouble-shoot them yourself. It's simple but time consuming which is why you don't want to pay someone else who's billing $80-$100/hr to do it for you.
Get a Haynes manual if don't already have one. Check/Replace your fuses, they're cheap and easy. Go to Radio Shack and buy some electrical contact cleaner and start cleaning and tightening every ground connection you can find.
Broaddus
Apr 13, 2014 09:55 AM
BackHouseZ
Apr 7, 2008 11:36 PM
dragon
Feb 11, 2008 12:41 PM
NwZXlover
Jun 9, 2003 08:29 PM
