Differential Cover
Old Oct 9, 2006 | 11:23 PM
Nemesis280zx's Avatar
Differential Cover
I'm trying to take off the cover to the differential and have no luck because the diff mount is connected to the lid and there is a long bolt that goes from the inside of the car through the mount and I dont know how to take that off to open the lid. My car is a 83 280ZX Turbo with an R200 diff and cv axle shafts. If anyone can help me in the removal of the diff cover process let me know. THANKS.
Old Oct 10, 2006 | 07:11 AM
Just two nuts on the cover to mustach bar, then one or two bolts from the mustach bar to body.... pull the mustach bar out & then you can remove the cover bolts.
Old Oct 10, 2006 | 11:22 AM
That single bolt through the rear bushing is not from inside the car. It is hard to break loose but it will unbolt from under the car. You take that off, then you can take off the two bolts holding that bracket to the diff cover.
I never tried to remove the back cover while the diff was still mounted in the car but I suppose it should be possible.
Old Oct 10, 2006 | 11:52 AM
Here's a pic of that mustach bar:
Old Oct 10, 2006 | 11:35 PM
I unbolted everything, but how do you break loose that bolt that goes through the bushing? I can't see how you take it off. Do you turn it? Do you bang it out? I tried everything, but have no results yet.
Well let me tell you my problem..... I was driving when suddenly my car was making a weird noise in the rear, then it it felt like something was banging, then the right rear tire seemed like it was jumping off the ground, like it was wanted to pull just on the right side. I thought it was the axle, but tht is fine. Now I want to check the diff to see if anything is bad inside. Do you guys have any ideas of what might do this?
Old Oct 11, 2006 | 07:14 AM
It's a bolt... stick a socket on there and loosen it...
Before you take everything apart, maybe you should check the right hub??? Also put the rear up in the air & spin both tires by hand to see what's going on. Better to do a thorough checkover before digging deep to find nothing.
Old Oct 11, 2006 | 10:32 AM
rear right brake caliper got stuck closed... ? maybe... or lug nuts falling off and the wheel was wobbling around
Old Oct 11, 2006 | 06:16 PM
jmmorriso's Avatar
Power tools! I lover power tools, justget the impact and torch and sawzall out, anyhting's possible then.
Old Oct 11, 2006 | 06:57 PM
jfairladyz's Avatar
I like the way this man thinks
Old Oct 11, 2006 | 07:27 PM
Well I got to put the axle back on and tire and spun both tires to see if I heard or felt anything. The results... I didnt hear or feel anything bad. Nothing clancked or grinded or anything. Seemed normal to me. I was going to check the bearings but dont know how to get to them. Do I have to remove the axle and take that nut off in the hub? Thanks again.
Old Oct 11, 2006 | 08:38 PM
Let me answer all these questions with one of my own questions... You don't have a Haynes manual do ya? If ya don't... Go to AutoZone and buy one.
borini63
Mar 31, 2011 03:20 PM
Texizgreat
Oct 1, 2007 10:10 AM
ATZX
Jul 19, 2004 07:19 PM
typeaproduction
Mar 14, 2004 07:48 PM
OlderThanMe
Mar 9, 2004 10:27 AM
