Differential
Old Aug 27, 2007 | 06:33 AM
Texizgreat's Avatar
Differential
Two questions:
One what type of Oil 80-90w?
Two how do I find out what differential i have when i went to get a gasket they listed 2 r100 and r 200
(April-1978 Datsun 280 z)
Old Aug 29, 2007 | 05:26 AM
Texizgreat's Avatar
thanks for all the help
Old Aug 29, 2007 | 09:26 AM
naviathan's Avatar
If you have a 4/5 speed it should be an R200. If it's an Automatic it'll be an R180. But with as old as these cars are it could have been swapped at any time. Check HERE and see if you can figure it out. Shouldn't be hard.
Old Aug 29, 2007 | 10:21 AM
Quick google search renders this:
R200 on the left... R180 on the right:
Old Aug 29, 2007 | 06:19 PM
Texizgreat's Avatar
thank you much
Old Aug 29, 2007 | 09:38 PM
nismo619's Avatar
r-200 is what i have on my 1982 280zx turbo i used sysntec 75-90 gear oil it was expesive as hell for me 17.99 a liter mine took 1.5 liters i used the rest in to clean out anything in the rear gears " GET A GAS MASK ! " that rear gear oil will make u vomit on smell and look alone. At least it made me feel very sick i think it was worse because i heated up the gear oil took it out on the free way then came home and changed it out.
Old Sep 1, 2007 | 07:18 PM
Texizgreat's Avatar
OMG What a Pain in the aZZ... I can not seem to get the mounting nuts loose. Also can not get the drain plug loose either.I am replacing bushings as i am going.
Old Sep 1, 2007 | 07:31 PM
Which mounting nuts? The 4 connected to the cross member, or the 2 on the mustache mount? Use an impact gun on the 4 base ones, or a breaker bar. You should also soak them in some PB Blaster for a few, before removing them.
Old Sep 1, 2007 | 07:56 PM
Goofyz's Avatar
Gear oil
also, never, and I mean NEVER washes out of clothes unless someone knows a secret that I never learned...
Old Sep 1, 2007 | 09:06 PM
Texizgreat's Avatar
Old Sep 2, 2007 | 12:03 PM
Texizgreat's Avatar
What is up with the drain plugs They are 3/8 or 1/2?
Old Sep 2, 2007 | 09:14 PM
Quite sure it's 1/2 inch...
Old Sep 3, 2007 | 07:49 AM
Texizgreat's Avatar
ummm errr i ment 1/2 or 3/4..... sorry
Old Sep 3, 2007 | 09:12 AM
BC240Z's Avatar
From: Kelowna B.C. Canada,.The Beautiful Okanagan Valley!.,.Canada's "Cali"
Drain and fill are 1/2 drive ( use a BIG breaker bar. these are TIGHT)
Z-bar mounts. 17 ML
Front mount. 14 ML
Front yoke 12 ML
Drive axles.. 14 ML
That help?
Todd/BC240Z
Old Sep 3, 2007 | 05:25 PM
Texizgreat's Avatar
Thank you
I gave Up going to take it to a shop that can get it on a lift. I wanted to replace seals and clean it out. but forget it...
Old Oct 1, 2007 | 09:27 AM
rxKaffee's Avatar
My diff has the two lower plugs with the inset hex-heads like the r200 on the right, but its not so rounded looking and kinda looks like the verticle rectangle shape of the leftward r180... any thoughts on which it might be? I've got an 82 or 83 5spd.
rx
Old Oct 1, 2007 | 10:10 AM
rx
I think you have RIGHT and LEFT mixed up.
The R200 is on the left, R180 on the right. If you have an 82-83 w/ 5speed, you have the R200. See this website: http://www.geocities.com/z_design_studio/
dan4227
Jun 6, 2012 02:14 PM
MikeZ
May 10, 2007 01:06 PM
bardabe
Oct 6, 2006 07:13 PM
Fast240Z
Sep 24, 2006 08:32 PM
OlderThanMe
Mar 9, 2004 10:27 AM
