Cold Air Intake Deminsions
Old Apr 9, 2014 | 07:14 PM
crazyDuDe380's Avatar
ok question i need the dimensions of the tube that goes from an aftermarket air filter such as a K&N to the throtle body. Any help? im making a carbon fiber one
Old Apr 10, 2014 | 09:50 AM
Is this a trick question?
It depends on the air filter. They are usually 3", but can vary. Once you have the air filter, you measure the diameter, and then you will know.
Old Apr 10, 2014 | 02:11 PM
rogerz's Avatar
Grumpy & Helpful
if you would really like answers that would help you and avoid flames give the following info when you post: year of car, n/a or turbo engine, stick or slushbox. Most of us can tell by the year what model you have ie 85T is a turbo z31. Z cars come in many flavors and they are all different. example 84,85,86 Z31's pretty comparable. there were changes in 87,88,89. in addition 300ZX can refer to two completly different cars the Z31 and the Z32. No mindreaders here the more info you can post the more likely you get a cogent useful answer
Old Jun 8, 2014 | 05:40 PM
Jason280ZX's Avatar
If i can remember, i think the outer diameter to attach a filter or even tubes from the filter to AFM is 2.75inches. I did the 240sx Throttle body swap, so the openings are the same throughout the whole thing onto the intake manifold. Rather than Big tubing to very small on the stock Throttle bodies. My info is based on the 280zx (s130s) Hope i helped.
cozyp828
May 20, 2009 12:00 PM
280ZX_AV8R
Jun 17, 2005 06:47 PM
blazen280
May 1, 2003 07:57 AM
stevenz300
Oct 6, 2002 09:05 AM
brownjack
Aug 18, 2002 11:23 PM
