Clutch Replacement = Engine Problem?
Old Feb 22, 2005 | 04:53 PM
DoTheDrew888's Avatar
I finished my clutch replacement today and now my car is running like crap. Would turning the flywheel cause the timing to get thrown off? Any suggestions at what might be wrong? I didn't do anything engine related, just put in a new clutch and got the flywheel resurfaced.
Old Feb 22, 2005 | 06:50 PM
theramz's Avatar
I have a present for you...
Check your vacuum lines and wires near the firewall. You might have snagged one when you removed the trnny bolts.
Old Feb 23, 2005 | 06:06 AM
I checked the vacuum lines already. I'll look again this afternoon when I get a chance. Could it be anything else though? Thanks for the help.
Old Feb 23, 2005 | 07:52 AM
280Z4ME's Avatar
Just a thought, did you put the pressure plate in the right direction. if you put it in 180 you could have issues. As for motor issues i dont know but it is something to think about.
Did it run like crap as soon as you started it, or did you drive it then it started to run crappy. The reason i ask is if you had a bad clutch then put in a new one you could have strechted your timing chain.
Hope any of this helps
Old Feb 23, 2005 | 07:57 AM
So the new clutch engages harder so it streched the timing chain?
Are you sure your wife didn't put a '93 Honda Civic timing belt on your Z?
Old Feb 23, 2005 | 02:37 PM
Skully's Avatar
i gotta few too...
is it sputtering, or is there noise, it wont go nice?
lil more plz....
lol Bleach ima come over there and slap you with a 3 month old trout thats been sitting in the sun...
Old Feb 23, 2005 | 03:16 PM
When I try to start it the car wont idle and then stalls. If I constantly rev it I can keep it running but after I let off the gas it stalls. Also, when I start driving it sputters and backfires a couple times and then drives fine as long as I keep the RPMs up. Im pretty sure this has nothing to do with the clutch replacement, its just a coincidence. I replaced almost all the vacuum lines today and that didn't help so I don't know what it could be. Any other suggestions?
Old Feb 23, 2005 | 03:18 PM
Skully's Avatar
get a timing light anc check the timing...
ive had trouble like that...my timing was off...but due to a chewed up crank seal that broke and got jammed in the dizzy gear and jumped a few teeth...ran like crap..sputtered, wouldnt go at all unless i kept on the gas, backfire too ...same stuff..
Old Feb 23, 2005 | 03:49 PM
icice9's Avatar
Super Siver & Black Stud
check the rubber boot thats cnnected to your AFM.. when you took out the tranny.. the engine ould have shifted a lil bit but just enough to have the boot come off...
Old Feb 23, 2005 | 04:07 PM
Nope, not that. Could it be the FPR perhaps? Just a guess.
Old Feb 23, 2005 | 04:34 PM
Skully's Avatar
was timing good?
Old Feb 23, 2005 | 04:38 PM
Yes, I checked the timing and it is fine. The car ran perfectly fine before the clutch replacement. Thanks for the help, any other ideas?
Old Feb 23, 2005 | 05:20 PM
280Z4ME's Avatar
The reason i said that is because I bent my distributor by dumping the clutch after installing a new clutch. I had been driving the car hard before the replacment with no trouble but as soon as i replaced the clutch i bent the ditributor. If it was weak and working because the clutch would slip a little. The car ran Ok at higher RPM,s but otherwise it ran like crap. I replaced the dist. and all is well.
Old Feb 23, 2005 | 07:01 PM
Well, I checked the AFM boot again (more closely this time) and it actually had slipped off at the bottom. That was the problem and now all is well. Thank you very much Ice for the suggestion and thanks to everyone else for your help.
Old Feb 23, 2005 | 07:04 PM
icice9's Avatar
rite on... i had that happen to me a while ago when i swaped out my tranny.. thats why i had a feeling thats what happend to your car
Old Feb 24, 2005 | 02:36 PM
Skully's Avatar
god damn know it all!
let us help too!!!
glad you got it working...! haha...
yeah did you support your engine when you changed out the tranny...if you didnt it can be back for the mounts...just a tip for later...i stuck coupla 2x4's under when the tranny was on and then dropped it so engine didnt move at all
Old Feb 24, 2005 | 02:56 PM
icice9's Avatar
hahahaha but what good would i be if i didnt share my vast knowledge of the 280ZX.. im just kidding man.. just like you.. im just here to help...
Old Feb 24, 2005 | 03:21 PM
Skully's Avatar
im here to LEACH OF BLEACH!
hahahaha
im like the slug in Futurama that attaches to the head and sucks up all the information!!!!
Old Feb 25, 2005 | 10:43 AM
dang, I was still betting on the Honda Civic timing belt. Write that one down Skully for when you can't start your Turbo engine. Check for belt....
...also, keep all snow out of oil pan. I gotta keep all this good info in my head for you to suck up.
Old Feb 25, 2005 | 02:36 PM
Skully's Avatar
haha...ill clean out the snow...
GTH
Jan 29, 2015 09:55 PM
zxguy1986
Jan 4, 2015 09:52 AM
r2doesinc
Nov 13, 2014 03:27 PM
sticky280zx
Dec 29, 2007 11:03 PM
Charlie
Sep 29, 2005 01:28 PM
