Throttle position sensor , zxt
Old 10-11-2003, 05:37 AM
Jimmys83Z's Avatar
Do you have an OHM meter and know how to use one? You will need one to set tps. Its easy to do........
Jimmys83Z is offline
Old 10-11-2003, 03:10 PM
Jimmys83Z's Avatar
1-I do this after car is warmed up for better idle.
2- with engine running disconnect TPS and locate terminals 29 & 30
3- Insert OHM meter leads into terminals 29 & 30. Meter should show continuity.
4- make sure idle speed is correct then have someone raise idle speed to 900 while probes are still in tps. As rpm's hit 900, tps should cut off, indicated by the ohm meter showing no continuity. If not you will have to move tps one way or other until this is achieved. If you cant set it replace it..........
Old 10-13-2003, 07:06 PM
Jimmys83Z's Avatar
manual says 900, I'll stick with it.........
Old 10-15-2003, 04:58 AM
Jimmys83Z's Avatar
I read what he had and it also said "follow TPS link in my sig IF you have a 75 to 78 280z with EFI" If you read all bonz post he has a 83 ZX I dont think what blue has applies on a 83. The 75 to 78 has a different type of TPS from looking at the pics. I would like to know if anyone has any info on setting up TPS on an 83 that would help performance. Always looking to sqeeze out as much power as I can...............
Old 10-17-2003, 04:10 PM
Jimmys83Z's Avatar
tps
Well was wondering what you found on your sticking prob. If you are still hunting for it check the butterfly inside the tps housing. Sometimes the get carboned up, dont know how, but check the through shaft for wear and see if you can see where butterfly may be rubbing housing...........
LSUDuke
08-18-2013 07:55 PM
jagarcia89
06-04-2012 01:37 PM
moorebl
04-15-2011 09:04 PM
thxone
10-22-2007 04:40 PM
assimilated420
05-12-2005 03:17 PM
Quick Reply: Throttle position sensor , zxt
