can someone look at their starter for me???
Old Aug 15, 2005 | 03:36 PM
vvillium3's Avatar
hey all,
just got my motor in my car, and I didn't label my starter(everything else but that and the alternator). I thought for some reason I would remember how it hooked up after 6 months....
so could someone tell me where there ground wire or positive wire goes on the solinoid...
thanks,
Jason
Old Aug 16, 2005 | 07:56 AM
Fleaicous's Avatar
You should probly pick up a haynes manual.
Old Aug 16, 2005 | 08:22 AM
davidjoe007's Avatar
If you are going to keep this car...go with the Factory Service Manual. Check the thread search for websites that have it. Courtesy Nissan in Texas has the FSM on CD rom.
Old Aug 16, 2005 | 10:31 AM
jfairladyz's Avatar
There are only two wire that go to the starter/solenoid. One is the main battery cable (+) and the other is a smaller (I believe yellow) wire that uses a spade connector to connect to the solenoid. Hope that helps.
Old Aug 18, 2005 | 01:58 PM
DoTheDrew888's Avatar
The negative battery cable grounds on the top bolt that is used to bolt the starter to the tranny.
Old Aug 21, 2005 | 09:06 AM
duckyz's Avatar
Yep!! And the positive cable goes on the copper stud on the starter. Bolt it up, and go!
El_Colombiano
Jan 18, 2013 03:36 PM
81 Black L28E
Jun 1, 2005 11:58 PM
dapper189
May 29, 2005 03:16 AM
AlongCamePeter
Sep 12, 2004 06:20 PM
