camshaft rocker arm
Old May 25, 2012 | 06:33 PM
immortal557's Avatar
camshaft rocker arm
ok so the keeper fell off the valve spring not even sure if thats what its called but its the little round thing that the rocker arm sits on top of the valve spring what i want to know is there any easier way of compressing the spring while the cam is on or iam i going to have to remove the whole cam. cuz rite now i loosen the rocker arm alot and try to put it back on but could not get it back on there cuz the rocker arm is still in the way any ideas thanks
Old May 25, 2012 | 07:48 PM
I gotta be honest... I read your post 5 times and can't understand what you are asking because of a total lack of grammar and punctuation.
I think you are asking how to get the lash pad back on? Remove the rocker, install the lash pad, install rocker.
Old May 25, 2012 | 09:09 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
I think he is referring to the lash pad
What I think he is trying to ask is:
How does he get the lash pad back on with the rocker arm being pressed against the valve spring by the camshaft.
Edit: Oops, didn't see your second bit Nismo.
I think he may be a little confuse on how to get the rocker off..
Old May 26, 2012 | 01:52 AM
yes the lash pad that is what iam referring too. and yes how do i get it back on with out having to take the camshaft off. like is there an easy way to put it back on. like can i just take off the rocker arm some how
Old May 26, 2012 | 01:55 AM
basically what nismo said on the second bit about removing and installing the rocker arm
Old May 27, 2012 | 02:17 PM
Switchtr3's Avatar
Just turn the engine till the valve is fully closed (camshaft is not pushing on that rocker at all), remove the rocker, put the pad back on, and reinstall the rocker. I've had a whole rocker fall off on each of my 280s actually. It's important to keep them properly adjusted on these engines. If you drive it hard they seem to have a habit of backing themselves off after a while.
TELOZ32
Feb 9, 2012 07:11 PM
Niku-Sama
Mar 16, 2008 01:38 AM
jmmorriso
Jul 30, 2006 08:37 PM
OlderThanMe
Oct 19, 2004 10:10 PM
