A/C Freeze12 vs real R12
Old Jun 20, 2011 | 12:02 PM
cpp280zx's Avatar
Excuse my lack of car knowledge but I'm trying to get my A/C working in the most cost effective manner and can't seem to find any clear answers when I searched.
Can I buy the Freeze 12 synthetic R12 and just use that? http://www.amazon.com/Freeze-12-Refr...8595626&sr=8-1
Is it that straightforward or are there some complications associated with this? I read somewhere that this can eat at the orings and possibly cause more damage.
Or should I be looking more toward actual R12 like this? : http://cgi.ebay.com/ebaymotors/R-12-...Q5fAccessories
I'm trying to avoid doing a conversion because it would cost too much since I probably couldn't do it myself.
I'm in socal so a working A/C is pretty crucial so I don't end up drenched in sweat by the time I get to work. Again, my car know-how is very lacking so if layman's terms are possible it would be appreciated. Thanks
Old Jun 20, 2011 | 12:10 PM
Freeze 12 has some pretty mixed reviews. Some people say it works, most don't.
R12 would be the best solution, but that ebay listing has gone way too high. I bought 3 cans of R12 last summer for $30. Here's one for $10 right now (http://cgi.ebay.com/ebaymotors/R12-V...item27bbd2561a). Remember that you will need to buy an R12 charge hose too.
R134a is another option. Our member BlueKitsune & several others are running R134a on a completely stock system. $40 for a conversion kit and that's about it.
Old Jun 20, 2011 | 12:54 PM
cpp280zx's Avatar
What's involved with the conversion though? Taking out the whole system?
Old Jun 20, 2011 | 02:48 PM
Having a shop put a vacuum on your system to make sure it doesn't leak, installing new fittings and refilling it with the correct amount of refrigerant.
Old Jun 20, 2011 | 03:32 PM
BlueKitsune's Avatar
Intrawebz Wizard
Mine was already drained out. All I did was attach the new fittings and fill the system with R134a.
Old Jun 20, 2011 | 03:57 PM
cpp280zx's Avatar
Hmmm. Good to know. I'll probably just go with the R12 if that can Nismo picked out stays that cheap or I can find another one. I'll only need one?
And this charging hose, right?
http://cgi.ebay.com/R12-R22-R502-CHE...aultDomainQ5f0
Old Jun 20, 2011 | 05:46 PM
How much you need depends on how much is still in your system. I can't remember the total lbs, but it's in the FSM (and the sticker under the hood).
As for the charge hose, you need a can tapper if you are going to fill w/ 1lb cans: http://cgi.ebay.com/ebaymotors/R12-F...Q5fAccessories
And I believe that ebayer selling that can for $10 has more listed.
Old Jun 20, 2011 | 07:59 PM
Remember that a lot of these "replacements" are COMPATIBLE and not actual R12 or R134A which means a substitute like propane.....
Old Jun 23, 2011 | 08:49 AM
cpp280zx's Avatar
thanks for all the info guys. I think I'm going to end up doing the conversion so I won't have any problem getting R12 in the future if it needs to be recharged again
cpark_12
Oct 1, 2012 08:29 PM
WildmaN
Jan 10, 2007 01:09 PM
280steveX
Apr 3, 2003 11:19 AM
