Brake pads, sway bars & mufflers
Guest
Posts: n/a
OK here we go , under the car . Going to change the brake pads, choices, there are always many . Whats the best material for this car??? Now the front (stabilizer) sway bar, changing the bushings from rubber to poly, Ok , here's the problem one of fasteners in the frame is striped, not the side where the stud is but the side where the bolt goes in, any ideas?? Also , Im changing the muffler, going to stay with the same size pipe , No cat, I just want a little more noise, any favorites ??? Btw this is a turbo ZZZZZZZZZZZZZZ.....Thanks
Guest
Posts: n/a
I picked up a s/s dyno max on ebay, mounted it , looks decent, car is still sleeping for the winter so I will have a full report in the spring. Replaced the rear pads with raybestos semi metalic. New tie rod ends , inner and outer, dust boots, & urathane bushings for both sway bars. Replacing the carpet looks like its going to be a pain............Good place to buy parts, check it out ,,,, rockauto.com ........Thanks
WanganDevilZ
Mar 6, 2010 02:30 AM
nka04a
May 13, 2006 12:38 AM
