BOV Question
Old Jul 22, 2007 | 10:18 AM
  #26
veyenyl's Avatar
Originally Posted by lifegrddude
Umm, it's still a maf setup so an atmospheric bov will stall the motor at times. When I switched from the stock efi to the Z31 setup, my Z was more prone to stalling from the vented bov. The stock efi didn't seem to be affected as much as the Z31 was from metered air being released.
That is correct. I was thinking MAP setup but typed Z31 setup.
Try it vented and see if it works out for you. If you're happy with it leave it. I tried it on an all stock motor at 10psi with a supra IC and didn't like it. It ran much smoother recirculated. Your car may respond different with a different BOV then what I used since the 1G DSM is not known for good sealing and quick response.
Old Jul 22, 2007 | 10:59 AM
  #27
the 1G BOV isnt, BUT, you can aactually crush the tops of them and they seal GREAT! its a DSM trick. lol. and the car isnt going to run like crap, its just going to be iffy between shifts. and whats so hard to see about it stalling the engine. its under boost flowing alot fo fuel and then POOF! all the pressure is gone since the BOV goes, it doesnt have enough air and the engine stops running, put it back in gear and its back to running. now with a recirc not ALL the pressure is gone there wil be a short little surge of air just enough till the injectors click back down to the non boost flow rate.
Old Jul 22, 2007 | 11:24 AM
  #28
ok, go get a 1G dsm unplug the recirc and you let me know that it doesnt run like ****.
Apparently reading skills own you:
My first bov was a 1G dsm one that at first I had it recirc'd. Then I removed the recirc hose & I felt no difference at all (also no difference seen w/ my a/f gauge). Huh... that's weird.
In more simple words, I ALREADY did that.
Old Jul 22, 2007 | 11:39 AM
  #29
no.... a REAL DSM! the actualy car not just teh BOV on your car. the DSM as a whole. reading comprehension owns YOU! i never said go get a 1G DSM BOV.... i said go get a 1G DSM and unplug the recirc. jerk. :P
Old Jul 22, 2007 | 11:43 AM
  #30
yeah... lemme just run out and buy a dsm (which is not a Z) and unplug the recirc leaving a nice vac leak... to prove absolutely nothing about how it will work on a Z (because again, a dsm is not a Z).
Old Jul 22, 2007 | 11:58 AM
  #31
thxone's Avatar
That's drizzle for shizzle my nizzle. You keep getting owned Snw...why you let him do that to ya?
Old Jul 22, 2007 | 01:20 PM
  #32
lifegrddude's Avatar
Externally Wastegated
Originally Posted by thxone
So these cars that run like crap when vented to the atmosphere, how much boost are they running, were the injectors swapped for larger ones, are they running higher volume fuel pumps??? Unless the BOV is leaking or venting at an idle all the time I don't see how it's going to stall an engine because as it was stated before the valve on the TB is still partially open at an idle or it would in fact starve for air and stall. I am sure there are other factors that is causing those engines to stall...maybe they can't drive a stick...it could be many things causing the engine to malfunction, but with 6 pistons and only a split second that the BOV would vent, I just don't see that being the cause of the stalling problem.
The Z31 setup runs like crap if you upgrade to much injectors for sure. My 440's will stall the motor if I leave the gear in D and let off suddenly at at low rpm in 2nd or 3rd gear. (~1550, the transmission shifts way too early to get to 3rd) In stop n' go, I have to leave the transmission in 1st and manually shift it to avoid stalling. At higher speeds and rpms it's not an issue though. I leave my bov vented because when I upgraded my turbocharger, I couldn't use the stock intake piping to the compressor, so I had no recirc line anymore. But like I said before, the stock efi wasn't really affected by a vented bov. I had 370's on the stock efi and never stalled once even when I tried the vented setup. The 370's on the Z31 setup was ok too, I only stalled it twice during the 8 months I was running that setup.
To answer the other general questions, I'm running 16 psi as my max, a larger fuel pump, 440cc injectors, etc. Stick driving skills have nothing to do with the motor stalling from a vented setup. If you don't mind a little compressor surge, you can tighten the bov to reduce the time it's open as well.
Old Jul 22, 2007 | 02:04 PM
  #33
i didn't get owned for crap, i made a quick anecdote to it and how it COULD POSSIBLY effect the Z, and nismo goes to from what i read arguing how a DSM (not the BOV on a Z) wouldn't do what i described. he just took it out of proportion and we misinterpreted on another all the way through. so it was just a stupid misunderstanding. we owned ourselves. don't be saying i got owned, he is equally at fault for this brew ha ha miss hap. i want apologies. lol
Old Jul 22, 2007 | 08:47 PM
  #34
Snwy... I was just stating that we're talking about a Z, not a DSM car. I would imagine that a DSM would run poorly if you remove the recirc because it's made (and the ecu is programmed) that way from the factory.
The simple answer to this long debated out thread is that a stock 280zxt can have a vented or recirc'd bov. So pick whatever you want and go with it. Yay!
Old Jul 22, 2007 | 09:10 PM
  #35
thxone's Avatar
Hey Snw, you know I am always kidding....never mad at you.
Hey, I heard a car tonight when I was getting gas...oh, by the way, my 280ZXT is back on the road...and it had a BOV and it sounded really nice...looked like a Nissan of some kind....maybe a 240sx but it looked longer. I also did something to my car....here, look at the pic:
Old Jul 22, 2007 | 09:21 PM
  #36
lww's Avatar
lww
Head Muckraker
Hey! Where'd your front bumper go?!
Old Jul 22, 2007 | 09:39 PM
  #37
thxone's Avatar
I don't know why I did it, I went out this morning to put the new Alternator on and all of the sudden I was taking the front bumper off...I never even second guessed it when I was doing it. The bumper and mounts are screwed anyway and after I got it of I finished fixing the car. I did start getting ideas for the front end once I got done with the car....we will see how it goes and I will post pics after. I think its gonna be cool though.
Old Jul 22, 2007 | 10:28 PM
  #38
i know, like i said, i mentioned it since we were on DSM's, 1G's, and BOV's being recirculated, than you said no it wont, but talking about teh 1GBOV on a Z and i thought your saying no the DSM wont do that, and we argued to true things thinking the other didnt know what we were talkin aboot. lol. its sorta funy if ya think aboot it. anyways, it would/shoulda never happened, i blame jonas. lol.
Old Jul 23, 2007 | 05:37 AM
  #39
Heat Rave R's Avatar
Wait, I'm confused: on my thread about bigger injectors for my Z31T ECU conversion, you said it could only handle about 10% bigger than stock without having problems. But if you had 370cc, that's much bigger than 10% of the original injector size.
Old Jul 23, 2007 | 06:42 AM
  #40
He was running a SAFC w/ his Z31 ecu & 370's.
Old Jul 23, 2007 | 08:43 AM
  #41
So as I prepare to finish up my '88 Z31T ECU conversion on my '82 ZXT, I find that I would need to splice in resistors to make the original fuel injectors run at the right impedance. I figure the better long-term solution would be to just get the correct high impedance injectors, in a larger size to meet my horsepower goals.
So what I'm looking is an affordable and reputable place to get injectors from that are:
1. high impedance
2. hose feed type (instead of o-ring)
3. +/- 370cc
So far, the only place I can think of is RC Engineering, which runs about $88/each. I'm just wondering if there are any other reputable injectors for a better price.
Also, would the bigger injectors cause me to fail smog due to more fuel at all rpms, or would the Z31T's ECU compensate?
In your original post, you didn't say nor specify if you were going to use anything else as a fuel controller or piggyback device, so I assumed you were just going to use the stock ecu and hope it'd compensate which will never happen on an injector that's >10% larger. As Nismo said, I used an SAFC with the 370's before having my ecu reprogrammed for the 440's (which still needs a bit of tweaking anyway). There was a writeup and a sticky made over a year or so ago since I couldn't find anyone that had gotten it to work on a Z. I would recommend leaning out a lot from my settings though as I was playing it way too safe on the top. My afr's were at 10.1 IIRC. In my opinion it's only safe enough to use the SAFC setup to a max of 1.0 bar of boost, because the maf of the Z31 tends to max out on voltage around 12 or more psi.
Old Jul 28, 2007 | 06:30 PM
  #42
thxone's Avatar
BOV...No Welding!!!
Check it out!!! Stock manifold and I got the BOV on without drilling or welding and it works!!! I had to get a copper plumbing T fitting from home depot and some hose clamps with a plastic T fitting for the vacuum line, total cast about $6. This BOV is not loud but you can hear it very clearly when you hit 10psi and let off the gas. It also did in fact help with the spool of the turbo. So, the BOV works ($17) and no mods to the intake (priceless)
Old Jul 28, 2007 | 07:21 PM
  #43
hughdogz's Avatar
That's pretty cool you can see it from the hood duct!!
Isn't that still partially "recirculating" by Tee'ing back into the intake manifold?
I think the stock plumbing doesn't actually recirculate back into the turbo compressor inlet, instead it bypasses the TB when you let off the boost.
It might run differently if you went straight from the BOV to the J-pipe (remove the tee) and plug the hose going to the intake manifold. I think this way it would vent 100% to the atmosphere...I could wrong though...
Old Jul 28, 2007 | 07:32 PM
  #44
thxone's Avatar
It sort of is I guess but it would be anyway cause that hose would still be there if I ran the BOV in a different location all by itself. So I just combined the two for it's simplicity.
That is how I did it at first...that hose is going to the Air Regulator plumbing. I plugged it and the car wouldn't run. Took me about 15 minutes to settle on this. It is fully functional though and boost comes on quicker now in second, third and fourth. The BOV is quiet with anything under 5lbs of boost but get decent sounding above that. I am happy with it. The only thing this is making me want to do quicker is a fuel rail, 310cc injectors and a FMIC...then I will go HKS SSQV...hopefully at 15psi with that BOV it will be louder
Old Jul 29, 2007 | 07:06 PM
  #45
thxone's Avatar
Well, still no problems with the BOV, I think I have discovered an easy way to mount a BOV with this type of mounting flange.
Old Jul 29, 2007 | 07:18 PM
  #46
That's not recirc'ing at all... notice how the BOV vents through those holes... it's not venting back into the intake. SO IT'S NOT RECIRCULATING.
Old Jul 29, 2007 | 11:14 PM
  #47
but what about the small hose going from the BOV to the intake? isn't that recirculating??
oh wait, no... that's the vacuume line that OPENS the BOV! hahaha!! I figured it ooot
Old Jul 30, 2007 | 10:21 AM
  #48
hughdogz's Avatar
Right for the BOV, but what about the air that tees back into the intake that doesn't go through the BOV?
I didn't literally mean recirculating (back to the compressor intake), that's why I had it in quotes...
It seems to me like the stock setup where it bypasses the TB, but now it has a controlled leak to the atmosphere too. Like you said, if you plug the line going to the air regulator and remove the tee, it won't run right since some air must still be bypassing to the intake instead of 100% through the BOV. Maybe I'm still confused on how the stock setup works...
That's awesome it keeps the boost level up! Do the RPM's still hang during shifts as much as stock, or do they drop faster now?
Old Jul 30, 2007 | 10:32 AM
  #49
Which one are you talking about? The hose I've highlighted in red or green? The red one is the stock hose... it goes where it should. It has no effect on the BOV. The green one is the vacuum signal for the BOV.
Old Jul 30, 2007 | 10:54 AM
  #50
duowing's Avatar
NisTuner
Man that's not a bad idea, I might have to pick myself up a blow off valve, but you say that there's definitely a difference when driving around when the boost comes on and what not?
