BOV Question
Hey guys and gals, I just bought a cheap BOV and I have a question. The BOV says it is good from 6-17psi which should be good for me at 10-11psi of boost. It has a simple hookup that is 1" (25mm) on the bottom. Now, I have a 1" hole in my intake from the emergency Pop Valve...can I put it on the intake or does it have to be before the TB? The pic is of the BOV I bought.
http://i26.photobucket.com/albums/c1...5150/S-Bov.jpg |
Crap...I just remembered how the BOV works....I haven't converted to a Z31 setup so I would have to put it before the TB...if I do the Z31 setup there is no TB so I could put it on the intake. Damn butterfly valve on the TB :120:
The final solution: I am going to use a stepped drill bit to drill a hole in the intake pipe from the turbo to the TB. I will then tap this hole to accept a threaded one inch pipe that I will then screw into the pressure pipe (it will be cut to length) I will then use a thick hose and sturdy hose clamps to connect the BOV to the smooth (exposed) side of the threaded pipe. I may also have the pipe welded by a muffler shop before the BOV is installed. I can see it all in my head....but as we all know I am not mentally stable (see my post on my female relationships) :icon_anal:
99.99999% of all cars have a TB. :D
I don't think there is a day that will go by that I don't have some kind of a brain fart, malfunction, oversight, or lapse in judgment :102:
Your BOV has to be recirculated until you switch to the Z31 setup. A 1st gen DSM BOV is cheap and works well at 10-12psi.
Yes, but it messes up your fuel map by conflicting with the position of the AFM and the actual amount of air being forced into the motor since the BOV is bleeding off air that would otherwise go into the combustion chamber.
Granted, as primitive as our ECU's are, it doesn't make that much difference, but it will result in the car running overly rich during the time the BOV is activated. Since this is usually on decel, it's not disruptive to overall performance. I still prefer a recirc system since it keeps the turbo spinning at optimal speeds between shifts. |
im gona put a bov on my na, for all that extra pressure it makes.
Granted, as primitive as our ECU's are, it doesn't make that much difference, but it will result in the car running overly rich during the time the BOV is activated. Since this is usually on decel, it's not disruptive to overall performance. I still prefer a recirc system since it keeps the turbo spinning at optimal speeds between shifts. I don't follow your logic on this...the AFM is before the turbo and the BOV is on a pressure pipe after the turbo, before the TB. On deceleration (lifted foot from gas) the butterfly on the TB is closed whether there is a BOV present or not, the BOV is simply venting that surge and keeping it from retreating back in the direction of the turbo. The injectors will continue to spray when the TB is closed with or without a BOV present so a car without a BOV should still go slightly rich on deceleration. The air that is still moving from the air filter through the turbo is moving faster than without a BOV but is only doing this for as long as it takes to shift...usually under a half a second when the driver is in "race mode" if you know what I mean. So if the car is going more rich than normal it is only for a split second. Ergo, this should have no bearing on ones choice for Vented or Recirculated BOV's. I think the choice is, do you want a loud Pssssstt or not? Did I just stump the Head Muckraker? :icon_super: |
The surge is being vented, that's correct, but that air has already been metered by the afm. The ecu thinks that air will still get to the combustion chamber and will have the injectors fire the amount needed for that air. No air plus too much fuel = rich. Which is why on some occasions you can shoot flames out the rear from running too rich. It's not detrimental to vent the blow off valve to the atmosphere, it'll just have you running rich for a split second or so.
Did I just stump lifegrddude? :icon_super: |
The air that's surging will still reach the combustion chamber man. It's not being vented so it will eventually reach the chamber. The tb is not 100% air tight or else it'd stall the motor at idle. All the air will do is oscillate back and forth until until it smooths out enough to enter. So you won't run rich without a BOV.
I see your point. Still, it will only run rich for a split second with a BOV so it's my opinion that it is not enough to not run a vented BOV.
that split second is enough to kill the motor though. thats the only real detriment to a non recirc. valve unless its a 1G DSM then it will run like crap since teh MAF gets improper readings.
Like I said earlier, I as well as Bleach run a vented bov w/ no probs. My first bov was a 1G dsm one that at first I had it recirc'd. Then I removed the recirc hose & I felt no difference at all (also no difference seen w/ my a/f gauge). Huh... that's weird. :D |
I run the atmosphere venting BOV and I still get about 22 city and 27 highway so it doesn't make that much of a difference on gas milage. If I got maybe 17mpg I'd wonder about it. |
Huh? None of that made sense... Why would a 1G dsm vented bov make the car run any different than any other vented bov?
but W/E im probably just a habitual liar right?
When I tried venting my 1G DSM BOV with stock electronics, it didn't run as smooth and half the time it would run rich enough to kill the engine. I guess you can run one vented if you don't mind black smoke on upshifts and crappier gas milage. It also depends on what BOV you use. A better quality BOV like a HKS SSQV will probably do a better job of not stalling than a cheap DSM BOV.
Umm, it's still a maf setup so an atmospheric bov will stall the motor at times. When I switched from the stock efi to the Z31 setup, my Z was more prone to stalling from the vented bov. The stock efi didn't seem to be affected as much as the Z31 was from metered air being released.
So these cars that run like crap when vented to the atmosphere, how much boost are they running, were the injectors swapped for larger ones, are they running higher volume fuel pumps??? Unless the BOV is leaking or venting at an idle all the time I don't see how it's going to stall an engine because as it was stated before the valve on the TB is still partially open at an idle or it would in fact starve for air and stall. I am sure there are other factors that is causing those engines to stall...maybe they can't drive a stick...it could be many things causing the engine to malfunction, but with 6 pistons and only a split second that the BOV would vent, I just don't see that being the cause of the stalling problem.
Bleach, I am with you on the good gas mileage thing....my '79 5-speed just got 53 miles (10-12 mpg est.) on a quarter tank whereas my '82 Turbo gets 112-115 miles (22-24 mpg est.) per quarter tank in the city with me getting in the boost often, my window sticker states an EPA estimated 20 mpg Hwy, and that's the only one it gives. Weird. |
