backfiring out the intake; won't rev pass 3000rpm
Old Jun 6, 2003 | 11:47 AM
It does sound like it might be running lean. I would suspect the throttle position sensor. You can open it up and clean the contacts as well as clean the connector that plugs into it.
have someone spray some throttle body cleaner or carb cleaner into the front of the AFM (with air filter disconnected of course) while you reve the engine a bit. If you get some more power to revv up higher and more smooth then you know it is a fuel problem.
Old Jun 6, 2003 | 02:17 PM
icice9's Avatar
Super Siver & Black Stud
you might want to check to see if you have any vacuume leaks..specialy around the air flow meter... also id check your timing posistion too.. make sure to see that the AFM boot is on tight and is not leaking any vacuume...
Old Jun 6, 2003 | 03:26 PM
icice9's Avatar
i use to have the same problem with my Z... when i took out my NOS system i still had a hole from where my nitros injector went in and when i would reve the engine it would backfire pretty bad.. then i plugged the hole and it went away... thats why i was thinking it might be a leak somewhere... if its not that id check the AFM...
Spencer
Mar 22, 2014 07:19 PM
jdmay84
Apr 7, 2012 04:01 PM
basbol13
Apr 13, 2008 10:28 PM
BaltimoreZ
May 16, 2004 04:16 PM
ralphy
Aug 29, 2003 09:23 AM
