back up lights (revers)
I am getting my 280 ready for inspection, and my backup lamps are not coming on. I get low power to the socket when checking with my metter. I cleaned the soket, and looked at the chiltons auto manule wiring schematic. the lights go to ascd system. what is that? I was thinking of checking the switch, but it bugs me getting low power to the socket, cause that makes me think there is resistance in the line, or a short. the lights are not lighting thogh. any ideas?
the bulbs are good, wich fuse is it because it isn't in the bood?
by the way nismo how did you mount the front blinkers in the air dam in the picture? I have the smae one and my blinkers have nothing to mount in the holes. I was thinking about making a fiberglass molld on the dam that will hold them with some screws.
Originally Posted by EatmyDust
the bulbs are good, wich fuse is it because it isn't in the hood?
No I took it all out. why should I have kept it? less weght.
they didn't send instructions, but I tried it like that anyway, but they did a shity job making it, and wouldn't fit right with the bumper frame on.
The fuses are good, so I am going to hook up to each fuse conection, and put the car in revers till I get a reading, if I don't get one then I will check the switch on the trans.
I checked the switch, didn't need my meeter thogh. one of the wires was disconected frome it. now I have to solder it back. thanks for your help Nismo and others.
i dont have bumpers under my car but i will be welding 2 bars across front and rear shock absorbers, or get aluminum square tubing and make my own bumper..., imagine hitting a light pole dead on...your engine will be in the hatch...
kr11zzz31
Sep 8, 2011 07:39 PM
ZCHondaCRX91
May 19, 2011 07:34 PM
waterdogzx
May 14, 2003 06:56 PM
pugliellidude
Dec 16, 2002 03:12 PM
