back up lights (revers)
Old Apr 25, 2006 | 01:11 PM
EatmyDust's Avatar
I am getting my 280 ready for inspection, and my backup lamps are not coming on. I get low power to the socket when checking with my metter. I cleaned the soket, and looked at the chiltons auto manule wiring schematic. the lights go to ascd system. what is that? I was thinking of checking the switch, but it bugs me getting low power to the socket, cause that makes me think there is resistance in the line, or a short. the lights are not lighting thogh. any ideas?
Old Apr 25, 2006 | 01:21 PM
KTM200-280zxt's Avatar
I have the same problem, Id check the fuse, make sure the bulbs are good. I checked both those on my car and they were fine so I am guessing there must be some kind of switch in the shifter that isn't working.
Old Apr 25, 2006 | 01:24 PM
Check your fuse... check to make sure the 2 wires are connected to the reverse switch on the tranny.... you can also use some Lime Away in the sockets to clean corrosion...
Old Apr 25, 2006 | 01:26 PM
OH... BTW, I would recheck the wires you traced in the Chilton manual. ASCD (Automatic Speed Control Device) is the cruise control.
Old Apr 25, 2006 | 01:35 PM
EatmyDust's Avatar
the bulbs are good, wich fuse is it because it isn't in the bood?
by the way nismo how did you mount the front blinkers in the air dam in the picture? I have the smae one and my blinkers have nothing to mount in the holes. I was thinking about making a fiberglass molld on the dam that will hold them with some screws.
Old Apr 25, 2006 | 01:46 PM
Originally Posted by EatmyDust
the bulbs are good, wich fuse is it because it isn't in the hood?
Should be a fuse in the passenger kick panel (under the passenger dashboard, by the front of the door).
The front turn signals are just mounted to the stock bumper frame. You did keep the metal bumper frame right?
Old Apr 25, 2006 | 01:59 PM
EatmyDust's Avatar
No I took it all out. why should I have kept it? less weght. I cut the bumper in half with a torch.
Old Apr 25, 2006 | 02:03 PM
LoL... Did you read the installation instructions??? You're supposed to keep the bumper frame & put the kit on over the top of it.
Old Apr 25, 2006 | 02:05 PM
EatmyDust's Avatar
they didn't send instructions, but I tried it like that anyway, but they did a shity job making it, and wouldn't fit right with the bumper frame on.
Old Apr 25, 2006 | 02:10 PM
EatmyDust's Avatar
The fuses are good, so I am going to hook up to each fuse conection, and put the car in revers till I get a reading, if I don't get one then I will check the switch on the trans.
Old Apr 25, 2006 | 02:19 PM
EatmyDust's Avatar
puting the car in revers didn't change any reading on the conections, so I guess that means it might be the switch.
Old Apr 25, 2006 | 02:30 PM
EatmyDust's Avatar
I checked the switch, didn't need my meeter thogh. one of the wires was disconected frome it. now I have to solder it back. thanks for your help Nismo and others.
Old Apr 25, 2006 | 02:31 PM
Wahoo! Another prob solved! and that's the end of that chapter!
Old Apr 25, 2006 | 04:43 PM
Skully's Avatar
i dont have bumpers under my car but i will be welding 2 bars across front and rear shock absorbers, or get aluminum square tubing and make my own bumper..., imagine hitting a light pole dead on...your engine will be in the hatch...
kr11zzz31
Sep 8, 2011 07:39 PM
ZCHondaCRX91
May 19, 2011 07:34 PM
waterdogzx
May 14, 2003 06:56 PM
pugliellidude
Dec 16, 2002 03:12 PM
Darrel
Jun 15, 2001 06:14 PM
