automatic to manual
Old Oct 22, 2009 | 08:21 PM
buckdec's Avatar
automatic to manual
so gunna b having my first car put in my drivway tomorow n its gunna b a 1981 datsun. gunna do a full tear down n rebuild got a few things of rust n that so thatll have to get fixed as i go along. but i was wondering is it possible to change it from the automatic that it is to a 5 speed manual? and if it is is it easyer to buy a parts car that has a 5 speed in it or is there a tranny kit u can buy or order all the parts online or how ud go about it?
Old Oct 22, 2009 | 08:24 PM
Sweets's Avatar
Usedta be Justin260z
It its possible.
If you have a 5 speed parts car, it will be a million times easier.
Do more research first.
Old Oct 22, 2009 | 08:36 PM
Welcome to ZDriver!!!
Click this: https://www.zdriver.com/forums/search.php
Type "auto to manual swap" or something similar & you will get results like:
https://www.zdriver.com/forums/showt...ht=auto+manual
and many more.
Old Oct 22, 2009 | 08:37 PM
BlueKitsune's Avatar
Intrawebz Wizard
You will need the clutch pedal assembly, the brake pedal from a manual ZX, the Master and Slave cylinder, a flywheel and clutch kit, 5 speed tranny and a manual drive shaft. Along with the console pieces and shift boot.
Best bet, either spend all day in a junk yard, or just buy a parts Z with a 5 speed. Its not a turbo is it?
Old Oct 23, 2009 | 12:14 AM
FubarI33t's Avatar
don't forget the hard line from master to slave . and the hole is already there for the slave, just unbolt the cover plate. It's really easy to do.
Tempast
Feb 15, 2013 07:00 PM
1983_280ZX
Aug 12, 2011 01:50 PM
anderz
Dec 29, 2004 09:49 AM
Heat Rave R
Dec 17, 2004 01:34 PM
zacksz
May 6, 2001 06:34 AM
