alternator upgrade
Old Apr 7, 2006 | 09:16 PM
Whitesmoke's Avatar
alternator upgrade
is there another alternator i can install to get more amps? im wanting to install a rather large sound system and i know this 60 amp isnt going to cut it. i know the quest alternator is 130amp could that be fited to the motor or no? i know it can on the VG motors.
and on an unrealted note is that injector fan really neccessary?
Old Apr 7, 2006 | 09:35 PM
lifegrddude's Avatar
Externally Wastegated
www.zspecialties.com
I don't know what the amps were on their alternator, but it's a direct bolt in swap.
Old Apr 7, 2006 | 10:24 PM
jfairladyz's Avatar
Some would argue that you should keep the injector fan but I've never used one and I've never had any problems in that area. It's the first thing to get tossed cause it's ugly and obtrusive. There are plenty of other people here that can verify the claim that removing it doesn't have any ill effects. Something for you to think about: It ONLY operates when the engine is shut off and above a certain temperature.
And on the company linked above: They offer direct replacement alternators in 105 and 120 amps.
Old Apr 7, 2006 | 10:28 PM
Whitesmoke's Avatar
awsome, thanks for the info from both of you
Old Apr 8, 2006 | 12:52 AM
apperantly a gm one wire alternator is a direct bolt on as well. i also took off my little ugly cooling fan.
Old Apr 8, 2006 | 01:02 PM
im using a GM one wire and it hasnt failed me yet, but im planning on getting a 120 amp alternator though.
Old Apr 8, 2006 | 03:57 PM
HybridS130's Avatar
I've tossed the aux. fan on both of my Z's. I agree with everyone else in the sense that no harm really comes from doing this. Also it makes working on that side of the engine a lot easier.
Old Apr 9, 2006 | 10:41 AM
hey hoov, what kind of car that alt. come from and do you have to modify the zeds wiring to make it work. and what about the pulley??
Old Apr 9, 2006 | 11:46 AM
its just a standard GM one wire alt. im not sure on how i did the wiring though, but ill sneek a peak during lunch,
Old Apr 9, 2006 | 01:38 PM
Yeah, I'm using the GM 1 wire as well. There isn't a spot for the alternator "charge light" wire, so just leave that unplugged. I had to modify the bottom bracket of the alternator to fit the Z bracket, but it was simple.
Old Apr 9, 2006 | 03:25 PM
i can get a 200 amp modified one, yummy.
Old Aug 12, 2008 | 12:55 PM
CWHammer's Avatar
Under My Car... brb
There isn't a "standard" GM alt. They have a different mounting "time" meaning the bolt holes are at different rotational locations in reference to the wire connector. This was extremely important on the old three wire alts because the connector that fits in the casing could end up in a bad location.
Old Aug 12, 2008 | 01:16 PM
< cough ... super old thread ... cough >
GM 305-350 V8 "one wire" alternators.... those are the ones we are talking about.
Old Aug 12, 2008 | 05:23 PM
CWHammer's Avatar
Under My Car... brb
Use the search get poked, don't use the search get poked. There's just no winning.
Now, tell me what you did to install your GM alt. Jeg's has a 100A that they claim kicks in at 880RPM.
Old Aug 12, 2008 | 07:15 PM
Niku-Sama's Avatar
eff good grammar
no melting wires with these 100 150amp alternators
Old Aug 12, 2008 | 09:56 PM
Cut the bottom bracket of the GM alternator to the same thickness as the 280zx one, swap pulleys, hook up power wire & ground wire, leave charge plug disconnected.
Since my engine is still on the stand, I'll take pics of it tomorrow for you.
Old Aug 13, 2008 | 01:53 AM
CWHammer's Avatar
Under My Car... brb
Sweet I'm looking forward to it. By the way how's the re-re-build going? Will you be back to tearing up the roadways soon?
Old Aug 13, 2008 | 11:04 AM
vrocious's Avatar
what cars over there came with the gm 1 wire? you say 305-350, does that include lsx series?
Old Aug 13, 2008 | 11:11 AM
All F-bodies (Camaro / Trans Am / Firebird), Corvette, and I think the Caprice Classics too... w/ the fuel injection motors. I told the parts guys I wanted an alternator from an 89 Camaro (I think...).
Old Aug 13, 2008 | 11:34 AM
CWHammer's Avatar
Under My Car... brb
I looked them up for an 88 Monte. The factory one is 94A which should be more than enough. I didn't get the idle current though. I have to believe that it's better than the stock Z alt. I have to go througgh the garage I know I have and old Z alt and I should have an old GM one too. I'll see what it takes to mount that puppy!
Old Aug 13, 2008 | 09:52 PM
Here ya go:
Old Aug 14, 2008 | 06:41 AM
CWHammer's Avatar
Under My Car... brb
Looks like that says Duralast DL7140M on the sticker. Now that makes it easy. What did you use to make the two piece pulley? The front looks like the cover of the idler pulley. She's looking good by the way. How long before you're done?
Old Aug 14, 2008 | 01:27 PM
That's the stock 280zx alternator pulley... it's 2 pieces. And I'll be installing the motor tonight / Saturday.
Old Sep 3, 2008 | 08:34 AM
CWHammer's Avatar
Under My Car... brb
Picked up my new alt on Fri. I got the CS130 style rated at 105A. I had an extra upper bracket and straightened it out so I won't have to grind away the lower mount. I get to keep the lifetime warranty that way. If I have to drill a new hole because of length I'll be happy. I can't wait to get this done my alt doesn't charge so well and I can take it back to get a refund since it had a lifetime warranty too.
LYK how it turns out.
Old Jul 16, 2009 | 09:38 AM
Z_lover's Avatar
Has anyone had issues with belt squeal due to the increased load on the V-belt? If so, was anything done to resolve the issue other than tightening of the belt or belt dressing?
