Alternator mix up
Old Aug 24, 2004 | 03:49 PM
DoTheDrew888's Avatar
Alternator mix up
Anybody have a diagram on how to hook up the wires the alternator. I didnt mark it when I pulled out my engine and now i forgot where they hook up. Help please!
-Andrew
Old Aug 25, 2004 | 08:50 AM
The red wire with the round end goes on the post marked BAT. Sometimes this post has a plastic base to it. The black wire might have an open ended connector. This is the ground. It goes on any of the other little bolts that connect to the alternator housing. it is actually not nessisary. The alternator grounds through hits own base on the engine block, but the wire is there as a backup ground. The L shaped plug can only go in one spot.
Old Aug 25, 2004 | 12:32 PM
Ok i think i got that, so that means the black battery wire goes to the starter motor? I think i might have the battery wires switched.
Old Aug 25, 2004 | 03:12 PM
Ok i got it all figured out. Thanks a lot guys.
Old Aug 26, 2004 | 08:35 AM
The black battery wire can go to the base of the starter motor. (could also be called a transmission bolt) Or, it can go to the side of the engine block. (or you can run multiple ground wires)
The battery wire should be too large to connect to the alternator.
Also on the alternator: if you have a resistor plug with two short wire connectors on each end, hook one end under the BAT bolt and the other goes to any ground.
Daniel Coffman
Apr 14, 2013 06:36 PM
koukiAE86
Jan 24, 2008 08:21 AM
Goofyz
Jul 10, 2007 10:26 PM
MetalTear17
12
Sep 7, 2004 01:42 PM
tt300z
Jul 22, 2004 12:06 PM
