80 280zx brake fluid problem
Old Oct 7, 2009 | 06:40 PM
jk11blueboi's Avatar
i baught a 280zx from a guy bout 4 months ago and i noticed there was a bottle of brake fluid next to the master cylinder. i decided to change the front and back brakes and everything was fine for 2 months. i dont drive it far, i only put 5 miles on it a day. after two months i noticed the petal go 80% to the floor. i put more fluid in and bled it and went along well for another month. it started drinking the container of fluid from the resivoior and i only drove 2 miles to work. i kept topping it off. i checked for leaks at the calipers, none. the only resevior that is draining is the first one farthest away from the booster cylinder?
Old Oct 8, 2009 | 07:47 AM
Welcome to ZDriver!
Have you checked the firewall at your brake pedal for fluid? If all 4 calipers are dry (You took off each tire & thoroughly inspected each one right?), and there is no fluid leaking from the outside of the master, then it's probably leaking from the plunger side.
Old Oct 8, 2009 | 09:42 AM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
I had the same problem. It would be fine, then the fluid would dissapear from the res, no trace of where it went. I replaced the master cylinder and all is good. The hardest part of the install was bleading the new master cylinder
Old Oct 10, 2009 | 11:00 AM
I started to take off the brake master cylinder and i noticed there was some sort of glue around it connecting to the plate to the booster, after i took it off, i realized it was leaking at the booster. i replaced it and now just need to bleed the whole system thanks for all the replys
jk11blueboi
Dec 19, 2009 09:45 PM
rtmorgan
Dec 3, 2008 08:26 PM
one_fast_300zx
Jan 8, 2007 06:54 PM
thxone
Nov 19, 2006 09:33 AM
cubfan1122
May 29, 2004 05:26 PM
