5000 rpm with backfire
when i start running the car on 1st gear at 5000 rpm it creates backfire, i checked the fuel injections they're fine.. i have a 1981 280zx turbo with a t5 swap from auto to std. i have a 3 inch pipe strait with a skunk2 muffler, any suggestions of what could it be.. thanks
Another thing you can do. Is check your TPS. When you hold the throttle lever at a steady spot. If the engine runs an erradic idle. You are too lean. So barely move it counter clockwise (to the left) Until it runs even on a steady throttle. Then tighten the screws while holding the TPS in the right spot.
Now these tips are from adjusting an n/a. I don't know how much different they are from a turbo. But hopefully it helps. Good luck.
thanks i just changes the timing chain and found out that is it was the pickup coil that was bad so i change the distributor from an 82 turbo and it fixed the problem with the back fire, know i need to check like u said the MAF due to is not putting enough gas to pick up the 6 1/2 rpm.. it only goes to 5 1/2
defreesw
11-01-2004 08:12 AM
