280zx throttle laggg
Old Feb 15, 2013 | 04:33 PM
ricksilvia's Avatar
hey my 83 na have a pretty goog lag when u punch the throttle from idle it is fine if u ease into the throttle or are already reving. also there is a push of air that comes out of the intake box when the throttle is jabed at
Old Feb 15, 2013 | 07:58 PM
A full tune up will do wonders for a tired motor.
Aside from that, we need moar detailz...
How many miles on your car?
When did the problem start?
Did it suddenly start?
What's the timing set to?
Have you checked all sensors and wiring?
Have you checked cap / rotor / spark plugs / wires?
Always start with the basics.
Old Feb 16, 2013 | 01:40 AM
Make sure you don't have any vacuum leaks. I just had this problem this past week or so. One night my Z would barely idle, until I unplugged the C.H.T.S. I thought that was strange, but it ran better. So I left it alone. Then the next weekend, I was messing around under the hood, and noticed there was a pipe that was not connected to the top of the A.F.M. So I plugged it in, and it idled weird. So I went over and plugged the C.H.T.S. back in. Did some adjusting on the A.F.M. and T.P.S. And it started running better. Unfortunately, I lost quite a bit of fuel from running real rich with the vacuum leak. I couldn't even get to 4k on the tachometer, without the Z kind of cutting out. Now it doesn't cut out at all at 4k and above. And is running better than it has in quite a while.
As Nismo said...start with the basics. And who knows, you might have the same type of problem I recently had. Good luck man.
Old Feb 17, 2013 | 08:21 AM
dont forget these cars have the dreaded afm. the flapper takes a second to react to a flooring so you get a delay. its not like the ecu is all that quick either.
rocky_dogtown
May 21, 2014 11:00 AM
Kevin Henderson
Mar 7, 2014 08:43 AM
NismoPick
May 14, 2007 08:32 AM
newb81280zx
May 1, 2005 03:28 PM
SurgeNJ
Apr 15, 2005 01:50 PM
